https://ngwclub.com/forum/viewtopic.php ... 81#p828672
Buggered rear brake line
while taking apart the rear brake assembly, the nut that holds one of the brake lines to the MC cammed out, so now i cant get the connector out. I was needing to rebuild or replace the MC anyway, but my question is - since I have to replace the line anyway, is it prudent to replace those rigid lines with like kind, or can they be replaced with conventional brake line? The only issue i can see would be making sure there is clearance somewhere for the lines to be routed.
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: viewtopic.php?f=30&t=71959
Build log video: View it here
BOTM November '22
BOTM November '22
Re: Buggered rear brake line
what year bike?
My 76 has conventional steel line running from the master cylinder to the other side of the swing arm. It hooked to a flex line (runner hose) there.
I replaced my rear lines on my '76 GL1000. I ran on braided Teflon line from the MC to the caliper with 90 degree banjos on both ends of the line.
I had a similar situation with having the connecting nut for the brake line round off. You can apply heat to the nut (torch) and MC and spray/soak with liquid wrench. Do this several times and on the last heating put the nut in a vice (don't crush it) and try and work it loose.
-P.
-P.
mine is a 1986. The routing seems tight for the hard line that runs back to the front caliper, but i think it could be made to work. or i can just ebay a new (old) line.
BOTM November '22
BOTM November '22
I replaced the whole thing with a stainless braided line in '97 and haven't had to worry about it since.
I believe I had a stainless braided line on the '77 before that but I don't have any pics and that was a long time ago so I'm not 100% sure.
Interesting. So you replaced the hard lines with braided? Once I lay this out I’ll take some measurements and see if I can get some made to fit.
BOTM November '22
BOTM November '22
Before I learned about vacuum bleeding I used to have a hard time getting all the bubbles out. I figured replacing it with one continuous line would reduce the places for bubbles to collect.
IIRC, you have to remove a fitting inside the master cylinder's output port.
- 3 Replies
- 991 Views
Last post by Easter
- 1234 Views
Last post by low-side
- 8 Replies
- 1179 Views
Last post by glltd@shaw.ca
