Triple tree bolt size?
I have 78 gl1000 that I’m fitting wire wheels and forks from early model gl1000.
I don’t have the bolts to go into the triple trees to tighten the forks. Does anyone know the length and dia of those 4 bolts?
Thanks!
Thanks!
Re: Triple tree bolt size?
Which one?
https://www.bikebandit.com/oem-parts/19 ... #sch401721
https://www.bikebandit.com/oem-parts/19 ... #sch403593
And I guess #7 on the upper triple which isn’t listed.
Number. 15 on the lower
Look here.
https://www.hondapartsnation.com/oempar ... ar-key-set
If you look at the earlier schematic for #15 it gives the size. All I did was search a parts diagram on an online distributor. Anyone can do this. Useful for lots of information.
![Wink ;)](./images/smilies/icon_wink.gif)
These part number descriptions aren’t correct.
#7 upper steering stem fork bolt - 10mm x 35mm
Doesn’t fit.
#15 lower steering stem fork bolt - 6mmx40mm
doesn’t fit either.
Any other suggestions?
Doesn’t fit.
doesn’t fit either.
These bolts are directly from the '78 I'm playing with right now. The left pair are the upper, obviously hex cap screws, 10x35mm, but with 1.25 thread pitch (fine thread). The right pair are the lower bolts, 10x40, 1.25 pitch as well.
Thanks so much. I think the coarse/fine thread is where it’s not working.
I’ll try those out!
I’ll try those out!
You're welcome. Hope it works out!
I believe almost everything on a Honda is 1.25 mm fine thread, except the smaller bolts which are 1.0 mm. Probably JIS.
- 6 Replies
- 437 Views
Last post by rcmatt007
- 0 Replies
- 396 Views
Last post by wayneperry
- 6 Replies
- 803 Views
Last post by low-side
- 8 Replies
- 502 Views
Last post by CYBORG
- 28 Replies
- 3808 Views
Last post by bladredhead
