16" GL1200 front wheel darkside conversion
- Lead Member
Has anyone done this for sidecar use?
Re: 16" GL1200 front wheel darkside conversion
Meaning, put the smaller, wider rim/tire on a 1000/1100 bike?
Someone else may remember, but I don’t recall a direct swap unless you swap the 1200, triple tree, forks and down. It involves a few changes for speedometer.
Others have taken a spoked early 75-77 hub and spoked a 3” 16” Harley rim to it.
If you're asking about installing a rear mc tire on the stock front rim, you might send a PM or email to (member name) Ken L. IIRC, he has or had one on his 85...
I wouldn't. There is no advantage in mounting a car tire on the front wheel and unless you seriously reduce the trail the wider tire will increase the steering effort quite a bit.
Darkside on the front usually refers to mounting a wider rear tire on the front, often for sidecar use or in combination with a car tire on the rear (known as "double dark side"). Sometimes the GL1800 folks refer to running a bias tire on the front as darkside, also.Sidecar Bob wrote:I wouldn't. There is no advantage in mounting a car tire on the front wheel and unless you seriously reduce the trail the wider tire will increase the steering effort quite a bit.
I wouldn't want any wider front tire than necessary, whatever type of tire it is.
- 22 Replies
- 2604 Views
Last post by CYBORG
- 18 Replies
- 1789 Views
Last post by rcmatt007
- 19 Replies
- 6132 Views
Last post by TheFieryMan
- 12 Replies
- 3527 Views
Last post by Lucien Harpress
