Brake pads wear
- andorragl
Brake pads wear
Today it was time to change the tires, when checking the brake pads I saw that those on the left side were completely worn but those on the right caliper had very little wear, even the pad on the piston side was much less worn than the one on the opposite side. Has anyone ever had this problem?
- 20201101_190823.jpg (150.36 KiB) Viewed 288 times
- 20201101_190957.jpg (140.37 KiB) Viewed 288 times
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
Re: Brake pads wear
With both pads not wearing like the other side, check to see if the piston moves freely and the caliper floats (moves) too. Possible brake line troubles reducing flow to that side...check the junction on the forks were the junction is too.
Re: Brake pads wear
Likely sticky guides as Oldwing suggested. Common trouble after sitting for a spell. These bikes were not designed to sit, go figure. They run too nice to subject them to sitting abuse.
- 17 Replies
- 989 Views
Last post by tlbranth
- 3 Replies
- 678 Views
Last post by 77Gowing
- 4 Replies
- 518 Views
Last post by pidjones
- 11 Replies
- 968 Views
Last post by jdvorchak
- 7 Replies
- 369 Views
Last post by Steve81GL1100
