With three bikes it's easy to neglect one for way too long, and that's what happened with my GL1000. It starts and rides okay, but there's a number of issues that kept piling up until (after letting it sit all last year) I couldn't put off addressing them any more. So, I got a bit drastic.
The two big issues are the clutch and the fuel tank. The fuel tank's been crudded up a bit since I bought it, to the point my reserve has never worked- I intend to change that. The clutch always had a bit of a moan every time I first started the bike, but it's gotten to the point where it's started to slip as well. But overall this is going to be general clean-up, freshen-up, paint-up, whichever else I need to do this winter.
I did notice a couple things after pulling the engine- first, the wiper on my oil sight glass is leaking. I'm hoping to seal this in a way that preserves functionality of the glass itself, but I'm still exploring options. Second, even after replacing the valve cover seals AND bolt seals, I have a MASSIVE oil leak from the left valve cover. Not entirely sure why, but it's on the list. And I may as well hit the water pump while I'm at it, because I'm getting both oil AND coolant out the weep hole, depending on the day.
But yeah- it's not going to be a full restoration, but I'm definitely fixing and cleaning as much as I can (and budget and practicality will allow).
