handlebar measuring question
5speed
Post by 5speed »
I have I believe the stock bars on my 76.
I want to raise them up so I'm sitting as straight up as possible.
I'm far to old for the crotch rocket position..my back doesn't like it.
I'm long thru the body.
I held the end of a tape measure in my hand, sat up in a comfortable position and measured from my hand to the grip and got 6".
Looking online they give the bar thickness but not the height of the bars..and how do you measure the rise? From the clamp area to the curve where the grip starts? Image
Re: handlebar measuring question
I do not know but I know the 78/79 bars are higher and much more comfortable to me. I also have risers under them that I think were part of the Fulmer tour package to clear the fairing. Works well for me but I think you would probably have to change the cables.
5speed
Post by 5speed »
Whiskerfish wrote: Sat Feb 13, 2021 5:03 pm I do not know but I know the 78/79 bars are higher and much more comfortable to me. I also have risers under them that I think were part of the Fulmer tour package to clear the fairing. Works well for me but I think you would probably have to change the cables.
I expect I will..and the brake line that is brand new. :cry:
I never noticed how low they were until I sat on it in the garage on the center stand..
I am leaned over a lot more then I am on my 1100 and the 76 is going to be my road trip bike so I want to be as comfortable as possible.
I thought about risers but the bars are quite high off the triple tree now..
rjdoles
Post by rjdoles »
I bought a 2005 Honda 750 Spirit about 10 years ago and really like the bike with the exception of the handlebars which were "close to" drag bars. I found their dimensions and got some that were 4" taller and had a little more pullback. Of course that meant that I had to buy longer throttle and clutch cables and longer front brake hose. The new bars changed the personality of the bike in a good way.
Here is a chart with some typical handlebar dimensions. Hopefully it will help.
https://www.vulcangadgets.com/files/bar ... ments.html
Started with an Allstate stooter made by Cushman and then a series of Honda motorcycles. 305 SuperHawk, CB750, VT600DC, VT750CD and then 4 years ago I left motorcycles for scooters with an Elite 125, Reflex 250 and Silverwing 600. Most recent is a barn find 77 GL1000 that I plan to resurect.
5speed
Post by 5speed »
rjdoles wrote: Sun Feb 14, 2021 8:07 am I bought a 2005 Honda 750 Spirit about 10 years ago and really like the bike with the exception of the handlebars which were "close to" drag bars. I found their dimensions and got some that were 4" taller and had a little more pullback. Of course that meant that I had to buy longer throttle and clutch cables and longer front brake hose. The new bars changed the personality of the bike in a good way.
that is perfect. thank you. anim-cheers1
ob1quixote
Post by ob1quixote »
I was able to use Rox risers, 1.75in, on my '79 without changing any cables or hydraulic lines.
1979 GL1000
2001 DRZ400
1983 CR480
5speed
Post by 5speed »
determined the bars are the oem ones.
ordered a set of 12" apes.
the stock bars have a 6" rise and with my rough measurement another 6" would put my position where I want it.
Don R
Post by Don R »
My brother installed the pullback brackets, they brought the bars up an inch and back a little more. I've owned 78 and 79, I think they look tall but find them comfortable so haven't tried to swap them.
5speed
Post by 5speed »
I mocked up the new bars today..they are perfect. I'm sitting in a much more comfortable position.
so the tear down started.. If all goes well tomorrow I'll have the engine out.
Paola Zago
Post by Paola Zago »
I take advantage of the argument to make an appeal, does anyone have a handlebar, preferably original for LTD, tall, original American, complete with wiring, levers and tubes for my 1976 LTD? I'd rather find it in Europe, to save on the high shipping and duty costs.
Thank you in advance
5speed
Post by 5speed »
A bit of difference. I think the throttle cables will reach but the clutch cable definitely won't.
I still need to mark and make the holes for the wires and the locating dowel for the controls.
Paola Zago
maybe I found the handlebar I was looking for in Germany, it comes from a motorcycle imported from Texas, I still have to combine the price. It has electric controls, but it does not have the throttle cables, the clutch cable and the first section of the brake master cylinder hose. can you tell me the american codes of these parts so i look for them? the part list shows different codes for different markets, and I would not go wrong in buying cables that are short.
Paola (Italy)
Paola Zago wrote: Tue Mar 30, 2021 5:29 am maybe I found the handlebar I was looking for in Germany, it comes from a motorcycle imported from Texas, I still have to combine the price. It has electric controls, but it does not have the throttle cables, the clutch cable and the first section of the brake master cylinder hose. can you tell me the american codes of these parts so i look for them? the part list shows different codes for different markets, and I would not go wrong in buying cables that are short.
Paola (Italy)
The US Stock 78/79 are already higher and the OEM cables are a bit longer to allow for that. The issue is that some aftermarket cables are made for that allowance and do not differentiate between the early and later models. The last time I looked places like motion pro only offered a one size fits all for the 1000 series. Here is a video I did a couple years ago comparing some different length cables. https://ngwclub.com/forum/viewtopic.php ... 29#p723304
Paola Zago
unfortunately, the Part list shows 5 codes for the accelerator cable A, 5 codes for the B cable, and 8 codes for the clutch cable. how do i know the lengths? how do i know if they are long or short? Has anyone recently purchased these cables for the American handlebar and can you tell me what part numbers they bought? it's a nice dilemma
Paola
5speed
Post by 5speed »
Paola Zago wrote: Tue Mar 30, 2021 8:40 am unfortunately, the Part list shows 5 codes for the accelerator cable A, 5 codes for the B cable, and 8 codes for the clutch cable. how do i know the lengths? how do i know if they are long or short? Has anyone recently purchased these cables for the American handlebar and can you tell me what part numbers they bought? it's a nice dilemma
Paola
if the ltd bars are the same as the regular 76 bars I can measure the cables I took off mine for you later today Paola.
