Question about 7v regulator
6adan
Post by 6adan »
The 1000 I am working on I thought was overheating but after checking more I do not thank it really is overheating it is just the gauge shows it is. Will the 7v regulator make the gauge do this? Thanks Dannie
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
Re: Question about 7v regulator
yes.
It also operates the fuel gauge so if that is ready faulty then odds are very high you have an issue with the 7V reg.
Sidecar Bob
Post by Sidecar Bob »
The best way to tell is to simply measure the output of the 7V reg and if it is anything other than 7V get in touch with Murray
https://murrayscarbs.com/product/7-volt-regulator/ (if you let him know which model you will be using it in he will send it with the correct terminals)
6adan
Post by 6adan »
Thanks guys, If I don't have one around in my pile of stuff I will check with Murry.
Explorer
Post by Explorer »
The folks at golwingdocs.com sell a really neat, fit it and forget it solid state one for around $30 for any year or model.
Sidecar Bob
Murray's is also solid state for only $20 US....
