We were heading out for a ride yesterday and her's wouldn't start. I boosted it and it started but when I unhooked the battery cables it quit.
I repeated this a few times with the same result although it gradually took longer to quit. the idle was going up and down on it then it would quit.
I pulled the battery out and noticed all the cells were down on acid. I assumed I found the problem.
I topped them up with distilled water, let it sit over night and when I put the trickle charger on it, it was showing fully charged.
I tested it with my multi meter and it's showing 6 volts.
So I called her and told her I think her battery is toast and she told me this is the third battery she's bought for the bike in the 4 years she's had it.
Between that and the cells being down on acid I'm thinking the bike is overcharging the battery.
Now the stupid question..
I looked up a voltage regulator for her bike and it has both a voltage regulator and a rectifier / regulator listed.
question A...does the bike have both or one or the other?
B. Is there a way to bench test them?
ETA..I was boosting off the battery in my truck but it wasn't running.
