Tech section wiring diagram question
flyin900
Post by flyin900 »
The one diagram with the Common Honda wiring colours at the very bottom of the page on the last entry with the yellow wire on the starter solenoid. It shows as just a yellow colour where I believe it should be a yellow wire with a red stripe.
I have found this and the other schematics to be excellent and invaluable in the wiring work that is sometimes necessary. I appreciate that Sidecar Bob did all this work initially and just wondered if this needs an update, or if it is correct.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
pidjones
Re: Tech section wiring diagram question
Post by pidjones »
Actually works for the most part on my '72 Triumph T150V. I rewired to negative ground and used Honda colors!
Sidecar Bob
Post by Sidecar Bob »
Interesting. I compiled that chart from other wire colour lists I found on the internet because I had noticed various errors in all of the ones I had seen. I didn't check everything on it but I'm fairly familiar with the colours used so I thought I had most of them right and if there were errors I would hear about them in short order.
It took almost 10 years before anyone spotted one (I hope there aren't any others that none of us have noticed).
All of the Honda wiring drawings I have show that the wire in question should be yellow/red so you are absolutely correct.
Here is the corrected version of the drawing. If someone can tell me how to replace the image in my gallery with this one without changing the address so that all of the links to the chart still work I will gladly do that
flyin900
Post by flyin900 »
Thanks for the correction, as it was a pretty small difference, yet someday 10 years from now it may save someone from scratching their head.
Cheers
Current Bikes:
DISPLAY MODELS:
Rednaxs60
Post by Rednaxs60 »
Lots of head scratching going on nowadays let alone ten years from now.
Bob - have you found a Canadian source for coloured/striped wire?
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Sidecar Bob
Just the box of wires salvaged from scrapped bikes & appliances I keep for when I need to match something.
So does anyone know how to replace the image in my gallery without changing its address?
Sidecar Bob wrote: Fri Oct 28, 2022 1:45 am SNIP
That might be tricky. Not sure it can be done but I will look at it.
Dr. Frankenstein
Post by Dr. Frankenstein »
THAT is Awesome!! Rather than having to look at the schematic and chase down what goes where; seriously Bob, that is a Huge help, esp. the "From" and "To"! That will make diagnosing stuff a lot faster. I printed that out and glued it to a piece of posterboard. Nice!
Sidecar Bob
WF: Thanks.
Dr.F: Check out the Colour Schematics link in my signature.
Bob Think I got it swapped out. I updated your original post (referenced in Shoptalk) with the new url so that is good. If you find any others you just need to replace the number of the file in the url. This should only affect links that go directly to the large version 1389649629 needs to be changed to 1667047400. The smaller version hopefully will update automatically.
Also I had to change the file name and remove the (Rev. 2022) from it.
Sidecar Bob
That seems to work. Thanks.
flyin900
Post by flyin900 »
Thanks again to both of you for the updated work. A lot for such a small change, yet is is now correct I believe. crossy.gif
Current Bikes:
DISPLAY MODELS:
tumb2 tumb2 tumb2 tumb2
