Any Way to Drain Carb Bowls w/o Making a Mess?
- Dr. Frankenstein
I was out tinkering in the garage today and was looking at the carbs on Rusty, my '78 GL1000 - is there any way to drain the bowls without getting gas all over the place? I was thinking a little flat tray with a funneled corner that slid in under the drains would be nice to have so you could just drain them and recover the gas - although I guess just putting a shop towel down to soak it up would do too, but it would still go all over the place. Do you guys ever do this?
- ritalz
Re: Any Way to Drain Carb Bowls w/o Making a Mess?
Probably not the best way but I just let it flow. When it's done I spray the area with brake clean to keep the gas stains in check.
- flyin900
I usually fold the blue Scotts shop towels (paper) into a wad of 2-3 towels folded in half and drain the gas into those. They seem to mostly absorb and contain the gas from each set of 2 carbs on each side, then repeat on the other side.
I tried the thin trays etc and just too clumsy and you spill the gas when removing anyway. This has been the easiest method for me in the past few years. If the gas soaks through the wad of towels onto the engine block, a quick wipe with another towel cleans it up quickly.
I use a set of long needle nose pliers to pull and position the towels under the carb bowls, as it is a little tight under there.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
Shut the petcock off, start the bike, go make a coffee and wait till it quits. It won't get all the gas but it will get most of it. Then do the towel under the bowl.
- Francis
- flyin900
I thought about this method too, yet the fuel pump will run dry a few minutes before the bowls empty and the bike quits. Since most of the pumps are older, how hard is it on the rubber diaphragm in the pump running it dry for a few minutes?
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- Dr. Frankenstein
Francis - 'Form-A-Funnel"?? Do tell...
I run mine with petcock off until they die, then drain the remainder into flat pans and suck that out with a syringe. Been doing it for years. Just takes about five cycles of the starter to get the bowls reflled come Spring.
I've done it on my 1100 since I bought it and it hasn't affected the pump yet. You could clamp off the fuel line between the pump and carb's..why I didn't think of that until now is beyond me.
- Francis
I got mine at napa, it was a bit cheaper than amzon but , the link shows you pics and stuff. Oh, by the way, stay away from the knock off, they're junk compared to the real deal.
https://www.amazon.com/Form-Funnel-Flex ... TFIYE?th=1
I bought something like that designed specifically for my fj. It isn't moldable thoughFrancis wrote: ↑Tue Nov 29, 2022 1:33 pmI got mine at napa, it was a bit cheaper than amzon but , the link shows you pics and stuff. Oh, by the way, stay away from the knock off, they're junk compared to the real deal.
- Francis
@ 5speed
Them things are great, lawn mower, snow blower, generator, pretty well anything. Well worth the money!
I love mine! Especially for the GMC before I got this, the oil filter was a real pita, now ,no spillage
let me guess...5.3 ls engine?
- Francis
the "engineer" that designed that block / oil pan needs to be keel hauled..
having said that..I watched an episode of engine masters last night and they ran 30 pounds of boost thru a junkyard 6 liter ls with a bone stock short block and made 1500+ horsepower.
