Here she is, strangely enough, when I brought her home exactly one year ago today - (note the gas tank on the bench behind her). God, has it been a whole year already??
DSCN2079 by Dr. Frankenstein1, on FlickrWhipped out the borescope and took a peek inside the engine; the gears were a bit rusty, but nothing that made my eyes go wide, so of course since the devil finds work for idle hands, I picked up a screwdriver and got to work. Tapped the case with the rubber mallet and loosened it up a bit and this came out:
DSCN2470 by Dr. Frankenstein1, on FlickrA nice mix of water, old oil and whatever those chunks are (old oil and schmutz, whatever that is); but after I convinced the side cover to come off it actually doesn't look too bad:
DSCN2465 by Dr. Frankenstein1, on FlickrHere she is where I found her, snugged up against a shed where the PO said she'd been since 'whenever'; but Hey! $50 is $50! And if anybody has one of those little round air filters next to the carb, please let me know:
Puch Barn Find by Dr. Frankenstein1, on FlickrThe clutch plates look a little rusty on the outside, but I have yet to take it off and apart to see what's what:
DSCN2467 by Dr. Frankenstein1, on FlickrIt did leave a bit of a mess on the inside though, but not bad. I've seen WAY worse. That big hole in the middle is supposed to be there, that's the 'viewing port', which is covered by a little plate on the outside.
DSCN2469 by Dr. Frankenstein1, on Flickr
DSCN2466 by Dr. Frankenstein1, on FlickrThe electrics look pretty good -
DSCN2070 by Dr. Frankenstein1, on FlickrThe kickstarter mechanism looks great; gotta love that Austrian engineering...
DSCN2468 by Dr. Frankenstein1, on FlickrAnd that's about as far as I've gotten. Winter's coming, and my garage will soon turn into a deep freeze, but my goal - before that happens - is to drop the engine and get the dang pistons out (front is to the left).
DSCN2093 by Dr. Frankenstein1, on FlickrThe front one (on the left) is frozen/rusted in, and I've already tried PB Blaster, diesel and ATF, heat, harsh language, brute force and multiple combinations of all of those, but she just doesn't want to give it up. I want to take the engine out and light a fire in the top end, let it burn for a few hours, cool, and see if it'll budge with the use of the 'proper motivation,' probably involving a sledgehammer - or at least my 5-pounder.
There aren't too many of these things left, but I've done one of these before - here's my runner:
DSCN2057 by Dr. Frankenstein1, on FlickrDon't let the looks fool you, this one has an upgraded coil, new wiring throughout, rebored head, new pistons, refurbished forks, new shoes and runs great; I kind of left it 'as is' on the outside because I like the patina. This newest one in the pics above I'm going to try to do a whole repaint, etcetera. Should be fun. The transmission only has six gears!
