1979 engine project
- dontwantapickle
1979 engine project
Gents:
Since not much new content is being posted here on the forum lately,
I figured that I would start a thread about my current project to give you guys something to look at.
OK, So... I bought a beat 79 1000 sometime ago, but as so many projects go, it was delayed because life got in the way.
Making money, Vacations and a problematic second cervical spine fusion put the project on the back burner until recently.
I'm now back at it.
So here's what's happening:
This is the bike as it was when I brought it home:
I'm now back at it.
- dontwantapickle
Re: 1979 engine project
A quick exploratory and... I had to take it apart:
Someone wasn't too gentle with these intake manifolds. Every one had different bolts.
Initial look at the carbs, Nope, I'm just going to set those aside for now
Last edited by dontwantapickle on Wed Oct 04, 2023 1:06 am, edited 2 times in total.
- dontwantapickle
Pulled the carbs and then the heads:
I wonder how many guys have tried to start their old bikes with this type of thing going on?
Old gas: The bores don't look bad - THAT'S GOOD! Looks like the belts are original: (another frame with damaged down tubes from the crash bars being over tightened)
Last edited by dontwantapickle on Tue Oct 03, 2023 9:41 pm, edited 1 time in total.
- dontwantapickle
Since I knew that I was going to do a bunch to this engine, I removed it from the bike and put it on my bench (desk):
Started with the heads:
They got the treatment and new valve stem seals and cam seals- dontwantapickle
I figured I'd just do everything to this engine short of splitting the cases.
All New Gaskets, Seals, Clutch, Water pump, Ignition, Paint:
- dontwantapickle
This engine was very dirty on the inside with a lot of sludge in the sump.
I don't think that the oil was changed very often.
I flushed out the block with diesel. It was huge messy pain in the ass - but it did a really good job of
cleaning out the oil goop.
- ritalz
That's a lot of updates all at once. Looks like you are well on your way to having another great looking bike.
- dontwantapickle
Yes it it a lot all at once. I'm just trying to bring everyone up to date.
Pics are from a couple of months back when I first started messing with it.
Then it was... start, stop, start, stop, start, stop, etc...
I've gotten in the habit of documenting my projects by taking pics.
Now that I've been back on this for a couple of weeks, I've made a lot of progress and taken more pics.
- dontwantapickle
A couple more pics:
Oil pump seal: Stripped the paint off of the engine.
It took me 5 cans of brake cleaner and a can of acetone to get it clean enough for paint: Fresh paint on some of the smaller engine pieces:
Last edited by dontwantapickle on Wed Oct 04, 2023 10:17 pm, edited 1 time in total.
- dontwantapickle
Painted the engine:
Interesting !
The cylinder walls you presented looked pretty smooth. You left the smooth surfaces alone, I trust?
Cliff (74yrs )
- dontwantapickle
Getting closer:
I just stuck the heads on temporarily for the pic
- dontwantapickle
- dontwantapickle
I have a 76 chassis that I have been using as an engine stand.
It works really well as It holds the engine securely, gives me a place to mount the radiator, coils, etc.
without all of the other stuff in the way.
And it's mobile, I can put it on or take it off the lift as needed which is a big plus in my book.
This is the 4th. different engine that has been in it.
- dontwantapickle
Here's the engine up on the lift, getting ready to put the heads on.
I have found that this approach works good because The engine is held securely in the frame and raised to a comfortable height.
The heads can be torqued a whole lot easier than trying to do it with the engine loose on the assembly bench.
