78-79 Seat, will it fit the 75-77 years?
DET17
Post by DET17 »
I guess this is a tech question.... not sure where else to ask it.
Does the later GL1 Honda seat fit the early machines, and look correct? I know it has a bit more bling/chrome on it, but I'm not aware of any other differences. I'm led to believe the 75-77 has it's own PN..... cosmetic difference of physical size/mounting?
Thanks to the sages.... this should be an easy one.
Lucien Harpress
Re: 78-79 Seat, will it fit the 75-77 years?
Post by Lucien Harpress »
Best I know, the seat profile is different, but the pans are identical. Early seats are pretty flat, while later seats had varying degrees of a step between the driver and passenger sections. So it should physically fit, but looking "correct" will depend on how particular you are about such things.
yes all 1000 seats are interchangeable
redglbx
Post by redglbx »
Yes as stated all 1000 seats will interchange,,, but (isn’t there always 😁) on the 78/79 seats where it contacts the back of the tank it is cut back on more of a taper that leaves a little bit of a gap at the bottom vs the 75-77 seats. But they all interchange.
In my opinion the 75-76 seats are some of the worst motorcycle seats ever, with their rounded tops they are like sitting on a lightly padded log putting pressure on the “boys”, not real good. The 77 seat is basically a copy of the 76 LTD that better match’s the back of the tank and is fairly flat & comfy. 78-79 seats are also flatter and Honda was trying to improve the seats with double density foam and such. They’re not to bad all together.
I personally have what I think is a 79 seat on my 76 that really isn’t to bad (but I really can’t remember which year it is) but a 300-350mi day is entirely possibly and still be able to walk at the end of the day. My .02
Shadowjack
Post by Shadowjack »
I put an aftermarket seat on my 75 that must be made for 78-79, because the front end contacts the tank shelter lid. I have to pull it back a bit to open it to get fuel.
DET17
Post by DET17 »
Thank you all for your input.
redglbx
Post by redglbx »
Jack, does your “aftermarket” seat have a bit of a gap at the bottom between the shelter and the seat ? If so it’s probably a 78/79 seat.
Shadowjack
redglbx wrote: Sun Sep 22, 2024 2:07 pm Jack, does your “aftermarket” seat have a bit of a gap at the bottom between the shelter and the seat ? If so it’s probably a 78/79 seat.
Couldn't say now. The manufacturer's name is still on the pan, but it's bolted down right now. It was a huge thing, plastic pan, big butt pockets for two people, with velour or something as a cover, but it was much more comfortable than the stock 75 seat. I did have the padding cut down, recontoured, and recovered with vinyl, but forgot to mention the interference in front.
Here it is when I brought the bike home. The ad called it "the world's most comfortable seat". 😏
DET17
Post by DET17 »
Well I did end up buying the 78-79 seat, allegedly a dealer "take off". Sure looks good in the pics, hopefully that good in hand. I"ll post up some pics of the installed seat on my 76 LTD.
redglbx
Post by redglbx »
Det, a 77 seat will be a close to oe for the LTD if you’re looking for originality. That king/queen seat looks as though it was an intended 75-77 seat.
DET17
Post by DET17 »
I'm actually looking for "near OE and comfy" for my 76 LTD. I'm keeping it pretty darn stock, but plan to ride it and am not a 100% chalk mark restoration guy. I've got one of the K & Q seats and will retain for any long rides, but I do like the OE seat look better and plan to run one for those 100 mile ride days.
redglbx
Post by redglbx »
Det, I have the oe seat on my LTD which is pretty much exactly the same as the 77 seat, I have ridden that seat for a 400mi day and the 79 seat on my regular 76 is also good for a 300-400mi day. I was way more uncomfortable on the king/Queen seat I had because I could not move around in the bucket, personally I prefer the 77-79 seats. The 75 & standard 76 seats are probably some of the worst I’ve ever sat on, just terrible !
DET17
Post by DET17 »
Thanks for the seat 411 ! My 76LTD is my first GL1.... had a GL1800 and did a 550 mile day, still felt good when I got off it. I don't plan to ride my Olde Wing those distances..... but the K & Q seat just looks a bit odd on a vintage bike. I'll test it for sure with the "butt dyno" but I like the looks of the 78-79 seat I just bought. Sounds like it will take care of those shorter days without issue. I'll test fit it, and see what the issue is with the surround / fuel entry area with said seat. Those 75-76 seats do look pretty horrible.
DET17
Post by DET17 »
Well I just unpacked my eBay score alleged 78-79 seat. I got to say, it is a creampuff and looks like it will be quite comfy.
Will mount on the 76 LTD when time allows..... here are some pics on the kitchen counter (wife's GF drinking night)
I cannot confirm.... does this appear to be the 78-79 Wing seat?
redglbx
Post by redglbx »
Det, Yepper that’s the same seat I have on my 76, pretty good seat ! Way more comfy ( everybodies butt is different though) than the oe 75-76 seat not including the LTD. I think that it’s a 79 seat but I’m not 100% on that. Good score !
