Many of these vintage GL1000 project bikes have significant rusting inside of the gas tanks. This requires removing the gas tank for cleaning. Getting the tank out can be challenging. This video shows how I extracted the tank on my 77 project bike.
https://www.youtube.com/watch?v=CoG7vaI0ISg
Removing the Gas Tank
Re: Removing the Gas Tank
Good job Len, thanks ! Only thing I would add is to be careful with the PB-Blaster and similar around the brake fluid rubber, it will ruin the brake fluid rubbers, otherwise, good job !
Thanks for the tip. I had not heard that about PB Blaster.
Len, PB-Blaster and a lot of those types of lubes are all a mineral based oil which is very bad for brake fluid parts, it will cause any rubber parts to greatly swell and disintegrate. Brake fluid is classified as a “vegetable” based oil which is typically considered safe to drink (I wouldn’t on a bet) .
Cleaning b-fluid stuff should be done only using a brake cleaner or clean brake fluid. Even 1 small drop of anything mineral based will ruin anything brake fluid related.
Excellent utube. Well done. Thank you
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
This “PB Blaster” topic perhaps would be a helpful new thread. The question I have is….brake master cylinders and calipers are often badly corroded and seized. I have always begun the tear-down process by soaking all components with PB Blaster. So….am I making things worse? What other solvent could I use to free up seized brake parts?redglbx wrote: ↑Fri Nov 08, 2024 11:23 am Len, PB-Blaster and a lot of those types of lubes are all a mineral based oil which is very bad for brake fluid parts, it will cause any rubber parts to greatly swell and disintegrate. Brake fluid is classified as a “vegetable” based oil which is typically considered safe to drink (I wouldn’t on a bet) .
- Lucien Harpress
Freeing parts using PB Blaster should be fine, with the expectation that all the rubber seals get replaced afterwards. Usually calipers that are that far gone need all the rubber bits refreshed anyway, so it works out.
Len, Lucien is correct in his views above, the only thing I would add is that the parts that make contact with the seals be thoroughly cleaned with alcohol and/or brake cleaner prior to the new seal contact. My .02
- 16 Replies
- 2478 Views
Last post by scootsx2
- 41 Replies
- 7843 Views
Last post by SnoBrdr
- 1 Replies
- 595 Views
Last post by Whiskerfish
- 1281 Views
Last post by Gowing
