Light Bars
LarryG
Light Bars
Post by LarryG »
Heyas,
Just wondering if anyone knows of a Running Light Bar that will fit or adapt easily to an '83 Aspencade? Want to mount running lights with turn signals underneath on either side of the headlight like a cruiser style set-up but can't seem to find anything designed for a Naked Wing. Anyone know of such a thing or have one for sale?
Found one post that mentions the JCWhitney bar for a Shadow 1100...does the year matter?
I'll figure out how to mount a small universal windshield later, one thing at a time I guess.
Thanks,
LarryG
rrgrassi
Post by rrgrassi »
Try Frenchy or BigT. They might know.
I am trying to figure out how to convert some small fog lamps to accept an ultrabright LED array.
Good Luck!
RRGrassi
Keep the rubberside down
lee stetson
Brass Member
Brass Member
Post by lee stetson »
i bought the alum billet lights and 1 inch mting brackets and mounted them on the lower side of the crashbars :-D
RETRO
Driving lights for GL Naked
Post by RETRO »
J C Whitney. Get the single light bar for the Shadow 1100, $20, and two lamps w/ bulbs and mount bracket. $35 ea.
longer bolts and some washer and mount to through front brake line manifold between the forks to the support.
Wire to ACC fuse block or add switch as the electrical system is going to be taxed by the two additional 55wt bulbs.
Some drilling and assembly required.
See the 'White Bike' by Retro.
