VAINCRE PROJECT BLOG
gregforesi
Re: VAINCRE PROJECT BLOG
#586
Post by gregforesi »
Nice job Sunnbobb.
One comment - I used that same breather filter but it turns brown and ugly after a couple thousand miles and needs to be replaced. The same one is available with the stainless mesh. It stays better looking and is cleanable.
2006 GL1800 (Brutus Maximus)
#587
The blades on my '81 were bakelite.
#588
from the factory? as old fogey and i both said, we were not 100% sure when they changed. and when dealing with old engines, i guess it is more then possible that they had been changed to the steel at some point. anyway i do know that the 1000 and the 1100 are the same. i'm sure when old fogey sees this he will track down when they changed :lol: :lol:
#589
Thanks for the tip Greg.
#590
As far as I could tell it was the original.
Easter
#591
Post by Easter »
Congratulations and best regards, Really hope this works out for you.
Gary
83 GL in process :IDTS:
dritzman
#592
Post by dritzman »
Having just had the pleasure of changing the water pump on my 78, I can say that they too were bakelite.
"Sometimes you have to go up really high to understand how small you are".... Felix Baumgartner (Red Bull Stratos jumper)
1978 GL1000
1995 CBR 900RR
2006 GSXR 750
#593
Well i put a metal one in, even though the bakelite one felt good. I dropped the bakelite one and broke it..:( was probably perfectly good! What a PITA to take that tranny cover off and put back on. The only thing that saved me was the fact I had replaced the screws with allens when the engine was out.
Easter
#594
Post by Easter »
AMEN to the pita of changing out the water pump while in the frame (1100) Just got mine running and discovered oil from the weep hole. Bearings were shot. Wished I had checked it better when doing the build. Waiting now for parts. Lots of O-rings and seals in there! But a good time to replace the fan sensor switch which is also bad.
#595
Honda should be spanked for that philips head that sits on top in a recessed hole!
#596
sunnbobb wrote:Honda should be spanked for that philips head that sits on top in a recessed hole!
There is a guy selling the bolt kits in the for sale section. :roll: ;)
#597
It is not a Phillips head, that is clearly a Cross screw. It makes you cross if you use a Phillips on a tight Cross screw.
#598
Weel she is done and shipped.. Air shipped to LAX. The muffler was only added for the pictures. The owner is having some fabbed in LA..
Ruffrider
My Album: http://www.ngwclub.com/gallery/v/wingmans/Ruffrider
#599
Post by Ruffrider »
Absolutely gorgeous action1 action1
Current Bikes I own:
1975 GL1000 Naked Wing, Old Faithful (alias the Ditch Dog)
(88,000 miles and broke down now)
1975 GL1000 Dresser ( project bike, still waiting for me to finish) 20,727k on speedo.
1979 XS1100sf (18,600 miles)
1984 CT110 2300 miles
1978 CT (Trail) 90 1,650 miles on speedo
Past Bikes:
1979 750 Kawasaki LTD
1976 Honda CB360
1975 Honda 400 four
1966 Honda 160 Dream (should've keep 'em all )
My album
Pony Ruiz
#600
Post by Pony Ruiz »
Congratulations!
another one leaves the nest.
It is what it is.
