NGW CARB REBUILD OFFER EXTENDED THRU JAN. 1 2015
- pistolpete
Special thank you offer
for NGW members only
[Note from Pistol and Moose] We are pleased to extend the special pricing for NGW members thru the year and ending Jan 1, 2015. Once more thanks to all of you who have supported Pistol Pete's Services.
Carburetor Rebuild:
NGW member price $385.00 for the GL1000 (Reg. $425.00)
$445.00 for the GL1100 (Reg. $485.00)
Rebuild Includes:
1) All parts of the Randakks kit except petcock seals and plenum screws – Pistol Pete’s will always replace old seals and diaphragms with new ones and ONLY Randakks approved parts are used.
2) Ultrasonic cleaning – An approved cleaning method for these carburetors
3) Jetting gauged for correct port diameters (including all emulsion tube holes)
4) Off idle fix for the 75 thru 77 - As recommended by Randakks
5) 77 jet needle fix - As recommended by Randakks
6) All parts checked for function, fit and serviceability
7) Engine tested for leaks, good throttle up AND….
8) Pilot screws balanced using PPS modified idle down procedure - PLUS….
9) Synchronized to .5"hg
10) Float levels re-checked
11) Carefully packed for return shipment to avoid damage- using double boxes to ensure protection
12) New fuel hose, GL1100 (pump to #3 carb)
13) Five new vacuum hoses and one new fuel hose, GL1000 (pump to #3 carb)
Nominal charges to NGW members for extra rebuild services below:
1) Shaft seals- new PPS engineered shaft seals installed
2) Stainless float post repair-Using Randakks Deluxe Float Post Kit
3) Cap and Intake polishing – Excessively worn, pitted or damaged items may not be great candidates, but we do have some inventory available for replacements.
4) NEW AT PPS! Four new OEM style plastic vacuum cap buttons installed (Note: color matched and CNC fabricated to emulate new OEM.)***
5) Cleaning of rust from steel parts and clear coated for protection. Order shaft seal option in order to qualify
6) Randakks High Performance Fuel Filter -available with rebuild as a convenient “one stop shopping” for NGW members
7) Additional parts replacement or repairs –as needed with customer notification and approval.
8) Return shipping via USPS (let us know your zip code when you contact us)
9) OEM float valves – 40-60% of most sets already have OEM needles and seats that only need to be reconditioned. Why pay for new if not needed? New valves are available to replace aftermarket or damaged OEM.
***Special offer for NGW members: We will install new PPS vacuum cap plastic buttons on any GL1000 set for $50.00 [set of 4] (Reg. $85.00) Ask us for details.
email us at petesgl@comcast.net and mention our rebuild offer or button replacement offer.
Carburetor Rebuild:
Rebuild Includes:
Pistol
Re: A SPECIAL CARB REBUILD OFFER FOR NGW MEMBERS
Thats a great deal. And just in time for the riding season
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Wish this was last fall. Can one buy a rain check?
- tomk1960
Great deal! Wbzat's your turn-around time these days?
- chewy999
That's a great offer, but dread to think how much the postage would be for me!!
- pistolpete
Tom,Great deal! Wbzat's your turn-around time these days?
Our usual turn around time is 2 to 4 days depending on condition of the rebuild.
Hope this helps.
Pistol and Moose
Pistol
- pistolpete
Chewy999,That's a great offer, but dread to think how much the postage would be for me!!
You might be surprised, we have rebuilt about 60 sets from Europe.
Give us a try.
Pistol and Moose
ngwoffer@gmail.com
Pistol
- chewy999
Would you have a (very) rough idea what it would cost to post, appreciate I'd have to get a quote from this end. Also, would I have to send the four manifolds?pistolpete wrote:Chewy999,That's a great offer, but dread to think how much the postage would be for me!!
Give us a try.
Pistol and Moose
ngwoffer@gmail.com
- Moostery Moose
- Wingerinsandiego
What a deal. As soon as I can dig up the cash, my carbs are headed to Tennessee!
1976 LTD
1985 LTD (SOLD) To support my naked obsession!!
I don't want a nickel, just want to ride my motorcycle!
- Moostery Moose
Sounds good Wingerinsandiego! Looking forward to working for you.
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out, screaming "MAN, WHAT A HELL OF A RIDE!"
76 Naked sulfur yella Wing
- pistolpete
Re: CARB REBUILD OFFER FOR NGW MEMBERS (ENDING SOON)
Hello folks,
Thank you for the response to this offer but like most things it will end soon.
If we can help, just email us at petesgl@comcast.net
Once more, thank you all for the support.
Pistol Pete and Moose
Pistol
