What Did You Do To Your Wing Today?
Re: What Did You Do To Your Wing Today?
Rode the 78 and worked on the 77 some more. Well ran it a bunch more just trying to verify everything is OK. Getting some smoke out of the RH exhaust and the # 1 plug is a lot darker than the rest. My Compression tester is acting up so I think I will have to save a few Pennies and buy a new one of those before I make any final decisions.
Finished cleaning up the Black 84 and warmed up the red 84 and the 82. Now I need to bring in the red one and change the timing belts and service everything so I can ride it to Wisconsin on the 27th. Man I love this black beauty. It's like a new machine.
Claude
Claude
- ritalz
Had a K1 parts bike pop up here in town. Saw pictures and it looks pretty rough. Shot a message to the owner with a low ball offer but have not heard back from him. May have ran him off. Don't need another project and my parts tubs are full. Probably need to sell some parts.
- ianstaley
I got mine last year they are cool aren't they.Oldest Sage wrote:Changed oil and added one of those spiffy chromed dipsticks. No more standing on my head checking oil.
- brianinpa
Finished up with a stator change on the 1200. Fired it up and now I am seeing 14 volts. Now to bleed that dang clutch!
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
- ianstaley
Didn't do anything yet, but I found this in my in box, thought it might just be a life saver.
http://www.banggood.com/Mini-38000mAh-J ... 1354616_27
- Bugdaddy66
Washed the bugs off the bike after a 200 mile run to town and back. Spring is big bug season here in Montana, hard to see through windshield by end of trip. Best use of a pressure washer, removes bugs without a scratch to the shield! Glad its in front of me, top of helmet just as bad.
Todd Logan (Bugdaddy66)
"Never argue with a moron, they'll always drag you down to their level and beat you with experience."
1978 GL1000 Daily commuter (SOLD)
1981 XS650 Hot Rod play bike (SOLD)
2003 BMW F650CS (Wife Bike)
2009 BMW R1200RT
2009 BMW R1200RT
- brianinpa
Bleeding the clutch went easier than I expected. Got the naked one back together and took it to the car wash to get a winters worth of dust and dirt off of it. It's nice riding with the wind in my face once more.
Brian
- 82aspy
dunno if some rear end clicking sounds is normal quickly moving the rear wheel back and forth a few inches, seems to be more pronounced at some locations, gotta narrow down the source of the noise, whether pumpkin or u-joint area, maybe wheel bearing
may be something more not uncommon with mileage? gonna check what 82a is like,
also feels like might be some very mild brake drag going going on, gonna see if the disc heats up at all on the next scoot with no use, then after fiddling with some varying applications, what happens
swingarm wheel combo are def tight
..far as movement goes
ngw quotes
- \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
ngw quotes
82aspy wrote:dunno if some rear end clicking sounds is normal quickly moving the rear wheel back and forth a few inches, seems to be more pronounced at some locations, gotta narrow down the source of the noise, whether pumpkin or u-joint area, maybe wheel bearing SNIP
You definitely want to slide the boot off and inspect the U-Joint and the splines on the back end.
- 82aspy
think there may be any connection with what seems to be very evident and easy onset of juddering with any load or pulling from below 3,000 RPMs?
seemS to go away completely past 3,000 & up & don't recall at this point but don't think 82a was the same, or at least not nearly as touchy
ngw quotes
ngw quotes
- Vermonter
A couple weeks ago DocRoot helped me install new timing belts and adjusters, and today I got around to timing the ignition. To my surprise, the previous owner installed a Dyna-S Electronic ignition! Adjusting the timing was easy once I figured out why my ignition looked so different from the manual... She runs good, I only have a couple more things to do before I get this '79 back on the road.
1979 Honda GL1000 (bobber?)
1951 Chrysler Windsor Deluxe (Project)
1987 Toyota Blue Marlin Motorhome
1985 Toyota Pickup Custom Cab Dually
2017 Toyota Tacoma SR5 4dr longbed
2005 Honda CRV SE (Wifes)
Like whisker said. Check the U joint and pull the rear end and check it. (Sorry I don't have a link)82aspy wrote:think there may be any connection with what seems to be very evident and easy onset of juddering with any load or pulling from below 3,000 RPMs?
- Dirt Road Cowboy
I took the old fork seals out of my new-to-me sliders to get them ready for the new seals.
My old seals were leaking a lot after I came down hard from an unintentional wheelie (sprayed oil everywhere!).
When I went to replace the seals, I found out that some PO had removed them by hammering a screwdriver along the outside of the seal, and prying them out, leaving bad gouges. I couldn't get the seals to stop leaking even with 50w oil, so it was time to get new sliders.
Then the bike broke down and sat for a few years.
The new sliders look much better with only a little scratching where the seals go. Light Dremeling and some sandpaper cleaned it up.
I think that I read somewhere that the new seals do away with the metal rings under the seal.
Is this correct?
Is this correct?
78 GL1000
DirtRoadCowboy.com
DirtRoadCowboy.com
AFAIK, the ring is still needed. Honda changed the design, so if you ordered a replacement, it may look different, but it is still required.Dirt Road Cowboy wrote:
Is this correct?
