CROSS OVER PARTS LIST
BIG T
My Album: http://www.ngwclub.com/gallery3/index.p ... ustom_wing
Post by BIG T »
this sticky is to list tried and true cross over parts. like parts from other Hondas and other sources that will cross over to our gl bikes. even if it is a year crossover, you can list it here. I know that Frenchy and Randak probably have a partial list they themselves use. lets build this one....T :?: :?: :?: :?: :?:
please donate to keep this site alive.
admit nothing, deny everything, demand proof!
Compiled from this thread and other contributions ... This list is actively updated as suggestions are made in this thread.
Timing Belts
GL1000 & GL1100
(requires 2)
  • Honda part #14400-371-04/14400-371-14
    Gates #T274
    NAPA #250274
    Goodyear Gatorback #40274 (AutoZone & others)
GL1200 (requires 2)
  • NAPA #NBH 250070
    Gates - #5043 or #T070
    Goodyear - #40070
GL1500 (requires 2)
  • Gates - #T275
    NAPA - #250275
    Goodyear - #40275
Radiator Hoses
  • Napa #7733 ($16.95) does both top & bottom
    Gates - #21008 does both top & bottom
    AutoZone - #B70834 ($9.95) does both top & bottom
    Fits 1973 to 1979 Honda Civic
    (may need new screw clamps, my stock ones worked okay)
Lower Radiator hose
Gates-22038 one hose, no cutting
Gates-21404 you can get two lower hoses from this one
Radiator Cap -- Standard style with 13 Lbs pressure, any auto supply store
  • NAPA/Belkamp #703-1445 (2/27/13, new #703-1697) or STANT #10229
    Murray #7713
    In Canada, Benson Auto Parts, Stant #10229
Thermostat
  • NAPA #101
    Stant #13868
    Murray #3868
Fan Thermo Switch
BECK/ARNLEY #2011614 and cost $14.13 at Rock Auto (will require adapting the plug to the new contacts)
Oil Filter - GL1000, GL1100 & GL1200
  • Honda Part #15410-426-010, 15410-422-004
    AMSOil SMF-101
    FRAM #CH6009 (comes with both o-rings)
    K&N KN401
    Napa #PS4940
    Purolator #ML16809
    STP SMO-09
    WIX #24940
Cam Seals Honda part #91209-371-003, Oil Seal (27X43X9)
  • Napa #ATM 2117994, Altrom
    Beck Arnley #052-2755, AutoZone
    Note: x3 on 1000s and x2 on GL1100s.
    Fel-Pro #TCS 45718 (comes with 2 seals per set)
Signal Flasher
  • NAPA #552 flasher relay, 2 pole
    Tridon EL12 at most autoparts stores ~$10 electronic flasher, stops slow/fast flashing. Try the 552 first.
Front Crank Oil Seal GL1000 & GL1100
  • NAPA #13954 (35x55x8)
1200 & 1500
  • Part #91201-MN5-003 (Discontinued #91201-MG9-005)
    Numbers on the seal are "A 8 SD 35 59 8 L HS". Measures 35 x 59 X 8
Also: Crank Seal, GL1000 and GL1100:
  • Timken P/N 223542, tapered (self-centering), cheaper
    National P/N 223542, non-taper
Used as: 1993 Infinity J30 rear differential seal. Most auto parts stores.
Rear Oil Seal for the clutch lever
  • NAPA #5410 Transeal, made by SKF 14x24x6
Valves, Intake/Exhaust Parts'n'More 10 and 15 bucks each respectively.
Spark Plugs - (1000, 1100) Stock is NGK D8ES.
  • D7EA or ND X22ES-U for cold climate
    D8EA or ND X24ES-U for standard operation
    D9EA or ND X27ES-U for extended high speed operation
    GL1200: NGK # DPR8EA-9 (Gap .035")
Spark Plug Boots
  • NAPA part # NGW8072
Serviceable Fuel Filter from Spectre
  • O"Reilly's Auto Parts, p/n 6932, about $10
    Hall's Speedshop online
    chasdog says, "I wrapped a piece of rubber around it to protect it and keep it snug - works great and you can clean it AND replace the filter element ... YES the filter elements are very easy to find - (O'Reilly's) keep them in stock - 3 to a pack."
Copper Squash Gaskets (exhaust header) - 1000, 1100, 1200
  • NAPA; Fel-Pro part number 60567 or 12-1002.
    The automotive applications are 1976-84 Honda 1.3, 1.5, 1.6 and 1.8 liter 4 cylinder engines. May also fit some 1991-95 Nissan 4 cylinders. Thanks to sunnbobb in this thread.
Regulator/Rectifier
  • Shindengen - #FH008EB, from 04-07 CBR1000RR and CBR600RR.
    "This is a true series regulator, it does not work by shunting current like all [of Honda's] previous models." Get more info in this post by socrace.
Wheel Bearings - GL1000 & GL1100
  • Front - 6302 2RS (x2)
    Rear - Takes a 6204 2RS & a 6304 2RS
    Readily available from any bearing distributor.
Head Gasket Job, Part Numbers, our thanks to Alwing17 for these.
  • Qty - - - Part # - - - - - Description
    2 -- 12251-371-306 -- gasket, head
    2 -- 12328-371-000 -- gasket, cyl head cover
    2 -- 19429-371-306 -- gasket, water elbow
    2 -- 91308-371-003 -- o-ring, oil orifice(small)
    2 -- 91305-371-003 -- o-ring, oil orifice(large)
    4 -- 91301-MB6-003 -- o-ring, coolant tube
    4 -- 18291-386-306 -- gasket, exhaust
    4 -- 91301-371-005 -- o-ring, intake manifold
    1 -- 91256-096-651 -- seal, tach cable
    1 -- 12390-371-405 -- insulator, fuel pump housing
    3 -- 91209-371-003 -- seal, camshaft
    8 -- 12209-MB9-003 -- seal, valve guide
    ** And timing belts, oil, silicate-free coolant, as well as a thermostat. The cam seals and valve guide seals are needed if you choose to lap your valves while the heads are off.
Speedo/Tach Rubber Seals, Honda #37235-323-700 (fits 1000 and 1100)
  • Western Honda Part #5 on the fiche . . . $11.36 each
    CMS NL product #37235323700 . . . € 10.00 each
link to metric wiring connectors http://cycleterminal.com/ (edited in by rcmatt 7/15)
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
Rear Oil Seal For The Clutch Lever
Napa Part Number 5410 Transeal
Made By SKF 14x24x6
List Price 6.41, With Discount Could Be Less, I Paid Only 4.17 With Tax
front end interchangability on 1000's: fork lowers, rotors, wheels, brake calipers, speedo, brake light sending switch
75-77: all interchange
78-79 all interchange
75-77 will not go on 78-79 without changing everything
actual brake cylinders will interchange
Thermostat, GL1000 and GL1100
  • Stant #13868
    Napa #101 ($7)
Spark Plugs, GL1000, GL1100
  • NGK #D8EA ($3)
And a huge list of Aftermarket Parts Numbers
from Chris' Goldwing Website.
There's lots of other good stuff at this web site.
BIG T
Post by BIG T »
THIS IS WHAT I'M TALKIN' ABOUT!! KEEP EM COMING...T
BIG T
for those of you who don'y "link" well....
Post by BIG T »
thanks Roady for this link...
Air Filters
K & N
GL1000 - HA-0800
GL1100 - HA-8080
GL1200 - HA-8084
GL1500 - HA-8088
GL1800 - HA-1801
Batteries
Odyssey - (sealed)
GL1000, GL1100, GL1200, GL1500 - PC680MJ or PC680 (*1)(*2)
GL1800 - PC545 (*3)
(*1) MJ stands for Metal Jacket. It is not necessary to have the Metal Jacket in our applications, therefore you could use the PC680 instead. Without the Metal Jacket, the battery is cheaper.
(*2) Battery installation requires re-routing of battery cables.
(*3) The PC545 is 15/16" lower in height than the OEM battery.
Brakes and Rotors
EBC Brakes
GL1200
Rear Rotor - MD1082
Rear Pads - FA69xx
NOTE: substitute the xx above in the pad number with GG for low performance pads, FF for mid performance pads or HH for high performance pads.
Oil Filters
AC Delco
GL1500, GL1800 - PF2135
AMSOil
GL1200 - SMF-101
GL1500, GL1800 - SMF-103
Carquest
GL1500, GL1800 - 85358
FRAM
GL1000, GL1100, GL1200 - CH6009
GL1500, GL1800 - PH6017A
K & N
GL1000, GL1100, GL1200 - KN401
GL1500 - KN303
GL1800 - KN204
NAPA
GL1000, GL1100, GL1200 - NAPA Gold 4940
GL1500, GL1800 - NAPA Gold 1358
Purolator
GL1000, GL1100, GL1200 - ML16809
GL1500, GL1800 - ML16817 or ML16819
STP
GL1100, GL1200 - SMO-09
GL1500, GL1800 - SMO-17
WIX
GL1000, GL1100, GL1200 - 24940
GL1500, GL1800 - 51358
Radiator Hose
(Cut in half to make 2 hoses)
NAPA - 7733
Gates - 21008
Spark Plugs
GL1000 (75 - 79)
NGK Standard Plug - D8EA-9 (Gap .028")
NGK Iridium Plug - DR8EIX (Gap .028")
GL11001(80)
NGK Standard Plug - D8EA (Gap .028")
GL11001(81)
NGK Standard Plug - DPR8ES-L (Gap .028")
GL1100 / I / A (82 - 83)
NGK Standard Plug - DPR8EA-9 (Gap .035")
NGK Iridium Plug - DPR8EIX-9 (Gap .035")
GL1200 / I / A / L / SEi (84 - 87)
GL1500 / I / A / SE (88 - 00)
NGK Standard Plug - DPR7EA-9 (Gap .035")
NGK Iridium Plug - DPR7EIX-9 (Gap .035")
GL1800 / A (01 - 05)
NGK Standard Plug - BKR6E-11 (Gap .043")
NGK Iridium Plug - BKR6EIX-11 (Gap .043")
Timing Belts
GL1000 & GL1100
Gates - #5119 or #T274 (2ea.)
NAPA - #250274 (2 ea.)
Goodyear - #40274 (2 ea.)
GL1200
Gates - #5043 or #T070 (2 ea.)
NAPA - #250070 (2 ea.)
Goodyear - #40070 (2 ea.)
GL1500
Gates - #T275 (2 ea.)
NAPA - #250275 (2 ea.)
Goodyear - #40275 (2 ea.)
BerlinKowgirl
Lady Winger
Lady Winger
Post by BerlinKowgirl »
I don't know if this belongs here, but this is what happened a few weeks ago. I wanted to change the bearings in the steering-head of my wing before going on a 5000 km roundtrip to France...but the bearings the Honda Shop sold me as the right one for my 1976 would not fit, they were way too big. After measuring the old bearing, I noticed that it has the same size as the steering-head-bearings of my 1978 CX 500's. I have no idea if that is unusual or not, but they did fit and I used a set of CX bearings that I had laying around. They are the tapered type.
Regards,
Peewee
Cheers! Peewee Image
1976 Honda GL1000 (put in shed, threw away key)
1978 Honda CX500 (the winter bike)
2001 Aprilia SL1000 (daily driver, my pride & joy)
And a bunch of projects not worth mentioning...
octane
Post by octane »
Here's what you do to find CROSS OVER PARTS.
(From one Honda to another, that is)
Go to CMS
...Click 'Honda Motorcycle Parts'
...in the 'Search Model' field; tap in your model..lets say: 'GL1000'
new page comes up;
...then, let's say GL1000 GOLD WING 1977 US
Click the underscored: parts-list
Now look for the appropriate sub-parts-list:
...let's say: 'FUEL PUMP / THERMOSTAT / POINTS'
Then the part you're looking for:
let's say #23 'SENDING UNIT' (that's the thermo switch)
and click the underscored line: 'SENDING UNIT'
a new page appears and it'll inform you that the part
is "Suited for models": and there's a list of all the Honda models
that use the same part.
In this case:
OK; it's a bit complicated but
this info can be quite useful, especially if you're looking
for second hand parts, like from a breaker.
Da' Supercharged Bulldog
Antoine de Saint-Exupery
OLD-TIMER
Zinc Member
Zinc Member
Post by OLD-TIMER »
We need to get this on a spreadsheet. There is great information.
Run What You Brung!
If They Get In Your Way!
Put Them In The Wall.
Or a page like this: http://www.elsham.pwp.blueyonder.co.uk/cx500/
(note the Parts Interchangeability Chart in the Owners & Users section)
Rad cap: Standard 13 PSI automotive type. Interestingly, every car my wife has owned has use the same cap except for her current one, and it's a Honda.
Paxton Gomez
My Album: https://picasaweb.google.com/1039177310 ... 0CAFERACER
Post by Paxton Gomez »
It seems that the rear light fixture in our wings is the same on virtually every Honda model from 1970 through 1978! :shock: :roll: ;)
"If only they would all just leave me alone with my old cars and my motorcycles, I would be content to let life, and the world pass me by"
J. Paxton Gomez - Paxton.Gomez@Gmail.Com
County of the Fallen Angels. Ca. 91206
toys...
'66 (ALPHA) Bronco
'77 GL1000K2 NGW CAFE Racer
'00 GL1500CY-Valkyrie 6-Cyl/-6 Carbs/1532cc
'02 VTX1800R2 V-Twin-FI/1795cc
'07 Chevy Colorado Crew Cab
https://picasaweb.google.com/103917731019176896112/TheThreeAmigas?authkey=Gv1sRgCIe0wJLpibP_ZQ
BLACKGOLD
My Album: http://www.ngwclub.com/gallery/v/wingmans/BLACKGOLD/
Post by BLACKGOLD »
Another oil filter for Randakk's spin on:
AC Delco PF1233 (GM#25161880)
Mike
Elvira-1980 GL1100 Custom
Black Betty-2000 HD Electra Glide
"we are on the cutting edge of cocking about" -Richard Hammond
kawracer
Post by kawracer »
BerlinKowgirl wrote:I don't know if this belongs here, but this is what happened a few weeks ago. I wanted to change the bearings in the steering-head of my wing before going on a 5000 km roundtrip to France...but the bearings the Honda Shop sold me as the right one for my 1976 would not fit, they were way too big. After measuring the old bearing, I noticed that it has the same size as the steering-head-bearings of my 1978 CX 500's. I have no idea if that is unusual or not, but they did fit and I used a set of CX bearings that I had laying around. They are the tapered type.
Regards,
Peewee
All Balls steering bearings lists the 76 GL1000 as part 22-1011 ( same as CX500 ) and 22-1020 for 77 - 79 GL1000, GL1100, GL1200.
78 GL1000
acmetim
case guards
Post by acmetim »
heres what i have found. can anybody confirm or deny this?
supposedly all these models have interchangeable case guards:
gl1000 75-79
gl1100 A/I 80-83
gl1200 A/I 84-87
any help???
tim forbus
75 naked goldwing.
http://www.ngwclub.com/gallery/v/wingmans/acmetim/
timforbus.com
