I had no idea! That is HUGELY helpful to know, the Kickstarterhas been the only thing really making me not LOVE the 1978 engine. Thanks for the info Eric!ericheath wrote:If you ever have the motor out again and want the kick start feature, ( It has saved me a few times) you can pull the back cover from your 77 and install it on your 78. Option is also there to swap 77 cams in. If you have 75-77 carbs, they'll probably be happier using the 77 cams.
Dark GreenWing 1977
- codyjames707
Re: Dark GreenWing 1977
I haven't done it, so maybe a search will pull up details that will be helpful.
- codyjames707
Hey everyone! Little progress moving along here, but any progress is good progress! I found a guy on craigslist who was selling a seat that was custom made for him, but turned out to be too big for his cb550. Luckily the goldwing is a BIG bike! I made the deal, brought the seat back to see how it fit and it is near perfect fit!
- Sugs
- wheeliedog
Some very nice lines starting to evolve here.
Good stuff Codyjames
naked 1980 GL1100 under construction.
- warhead_71
- My Album: https://www.ngwclub.com/gallery3/index. ... _71?page=2
That seat looks like it was made for your GL. Are you planning to add a rear fender or go without?
- hornetjo
- Brass Member
Wow the rear is really coming along, great progress!
- codyjames707
Hey Everyone! Long Time, no posts! Just wanted to show what I got done yesterday..
I have the solo seat, but I just needed to secure it to a seat pan properly. I decided to do some at-home welding and make some bracing for the rear of it, so I did some card board cut outs to get general measurements. The only thing I forgot to anticipate was the rise of the seatthe further it goes back.
Here was the genereal process:
THEN I BEGAN WELDING ONTO A STOCK SEAT PAN
As you can see, I made bracers for each little panel to make sure they're sturdy.
Then I welded on small little 2 inch squares to the bracers and then welded on the nuts that the bolts will connect to.
- codyjames707
And then I connected the bolts and it was a pretty clean fit! I will be adding some irrigation tubing to the welded ribs to pad the metal and dampen any shaking, then a little 3 inch long piece of square tubing to secure the front, fresh paint and it'll be all good!
Not the prettiest thing, but it will all be covered anyways!
- BikeMaine
Looks good, using those bolts?
Some stainless pan-heads would look pretty good.
Kevin
1982 GL1100A
1982 GL1100A
Gowing
Just re read all your posts, good work,
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- codyjames707
Gowing wrote:Just re read all your posts, good work,
Thank you GoWing! I've been slow at it, but it is coming along. Unfortunately when I mounted the seat to the bike, it seems to be sitting a bit too high for my taste; so another round of fabrication starts!
- codyjames707
It is time for me to start thinking about headlights, and I was wondering about some of your inputs on what would work..
I'm not trying to spend too heavy on a headlight set, but these seemed to be in a nice simple middle ground. Wondering which ones you guys think would work best, or if you guys have any personal experience with these change outs.
Here are my two options I am thinking about (Links Provided):
https://www.amazon.com/OSAN-Motorcycle- ... motorcycle
OR
https://www.amazon.com/Speed-Headlight- ... motorcycle
Both seem good to me, but I am curious for some input!
OR
Here's my first impressions.
From both Amazon listings:
The first light assembly ships with an H4 35w bulb. The lens is PC. I suppose that is Polycarbonate? Perhaps the $19 price reflects that a higher watts bulb would damage (melt?) the lens. Plastic bucket, too.
The second light assembly ships with an H4 55/60w bulb. No mention of lens material, but I'd have to believe it isn't PC.
Has a Metal bucket.$59.
- codyjames707
Yeah, the first was defenitely the "eh" one. Any suggestions on an aftermarket headlight? Im at least trying to get the back end of it to be black and not all chrome...gltriker wrote:Here's my first impressions.
