I believe that is a unit that could be mounted on a bike to provide .... oh heck, I read your PDF and I can't even remember what all it said. I just wanted to raise my hand.mikenixon wrote:And no one is going to comment on this tool?
I recently upgraded from my fish-tank-air-4way-valve-and-single-vacuum-gauge-hand-built unit to one of the $60 units like this one. You can indeed, calibrate the individual gauges but the covers are a bit of a bear to pry off (leveraging 2 flatheads against each other finally got it done) and the set screw takes a lot of force to move. I'll be using for the first time tonight as a matter of fact. Well, maybe not since I haven't adjusted my valves yet. Tomorrow then!
 Look like the ones mentioned at the end of the study.  They even have damping valves.  Cool.  Be curious, I was going to say, now that we know they can be calibrated, if once calibrated they stay the same at higher readings.  But, you know what, they don't need to.  If they are calibrated at the vacuum level that corresponds to idle on your bike, that's all you need.  However, on another bike of a different model, might be they should be calibrated again as their vacuum level might be different at that bike's idle.  This might be needed even if you decide to adjust your idle from one rom to another on the same bike.  I'm just thinking out loud here, knowing their economy origin.
