how much work?
- Lead Member
how much work?
I have seen this bike at the Barber Motorsports 10th Vintage Meet at the Barber track in Birmingham, AL in 2014. I have been in love with this bike since I saw it. I never got to talk to the builder, so I have no idea what it took to build this. So here I am. Can you give me a general overview of what would take to do this to a GL1100? The rear frame mod is obvious.
- dontwantapickle
Re: how much work?
relocate the battery and electrical stuff from under the seat and find a gas tank that will straddle the backbone.
- wingrider
Re: how much work?
If you really want it to look like that, you also get to cut the upper part of the seat frame and put that kink in it. Get some low bars, and some aftermarket megaphones, and a catch can for your coolant. Once you have all that, then make it your own.
Re: how much work?
The above advice is good, and I'll add a few details. First, the bike pictured is a 1000, which means that some of the 'looks' you might find appealing would require a bit more work if you're staying with an 1100.
Spoked wheels, '75-77 only. Significant modification/ part swaps would be needed, but not impossible.
Headers. I believe '75-77 headers are pictured. '78-79 headers are similar, but have a more pronounced 'upturn'. All 1000 headers have a slip-on flange to mount the muffler. 1100 headers are 'heavier' looking, not really tubular, and have no flange. Each side is a welded, one piece unit from header to tail pipe. All 1000 headers will fit the 1100 engine and frame, but clearance near the swing arm is kind of tight. Definitely doable, if you plan it out.
Most everything else will depend on your imagination, determination, and monetary denomination(s).
- Lead Member
Re: how much work?
Thanks for the responses. I just love that look, but for me, the bike will be a pusher for a sidecar rig. It doesn't sound like that look requires any major modifications.
- 230Rocket
Re: how much work?
What they all said plus an unlimited source of patience. Things do not always fit first time, ideas need to be converted to actions, your vision up against your determination will do it.
Get a donor and join the chaos.
Cheers
Dean
Cheers
Dean
1982 GL1100 Fat Turtle
Re: how much work?
Pretty sure it was also lowered some. Nice patina for sure.
Re: how much work?
Remember this bike well "El Guacho" if I recall. Deceptively (un)simple modifications. But making it work as this builder did is a real challenge.
