Hi fellow Gold Wingers.
I am restorating a '75 GL1000 and there is a crack in the seat vinyl. The crack is around 1 inch but there is more crack forming.
I don't want to get a new cover yet...
If I can use the original cover without it cracking more I appreciate all good wises.
Stay safe,
Karlott
Seat crack - what to do
- Lucien Harpress
Re: Seat crack - what to do
Apart from some black duct tape there really isn't a whole lot you can do, apart from a new cover. Thankfully replacing them isn't a hard job, but once the old one starts to go there's no good way to fix them that doesn't involve removing the cover in some way.
cfairweather
I would just put a new seat cover on it. A good place to get a high quality cover is from Z1 Enterprises.
https://www.z1enterprises.com/catalogse ... Seat+Cover
If you can soften the remaining material to prevent future cracks, then I have had good luck with sewing the tear with fish line then using liquid electrical tape to cover the stitches and crack. Put a large weight on the seat while it dries to cut in half the flex for your body weight. Has held up well for 4 year for me.
cfairweather
If you decide to repair the tear, and I don't recommend it, I have a suggestion that works pretty good. Cut a piece of high quality duck tape to fit and slide it underneath the seat cover where the tear is located. Work into place where you can press one side of the slit onto the sticky tape. Then work the other side of the slit onto the tape where you can barely see the cut. Then use a small amount of black vinyl glue on the slit to make it more durable and less noticeable.
