Every build needs a name. This one relates to a proverb repeatedly told to me years ago by my supervisor when I would approach him for additional equipment. The proverb goes something like this: a camel, fearing the approaching sandstorm sticks his nose in a nearby tent and makes a pitiful noise indicating his fear. The occupant of the tent sees the camel, hears the wind and decides to allow the camel in. As the camel slowly makes its way into the tent, the man is shocked at the size of its head and the length of its neck, then comes the long front legs with gigantic feet, next the shoulders followed by an incredible hump on his back that will barely fit through the tent opening. Then comes the second hump --well you get the picture, never invite a camel into your tent.
So why name a motorcycle after a camel? Well once you start the build the humps just keep coming and costing more and more. But I have done this a dozen times so I know more or less what I am in for.
In a previous thread I introduced the bike, a well used 1983 Aspencade that had been stripped of its tuperware and some work was already done. Fresh heads, fresh carbs (reportedly) and several new not yet installed parts. I bought it with title for about the price of the Randak carb kit along with a title. But most of us know that is just the nose of the beast!! Yesterday I started doing a full strip down which is almost complete as of this afternoon. My plan is to paint the frame and engine both black so I have opted to leave the engine in the frame, at least for now. There is a small amount of rust in the usual spot beneath the battery box so sandblasting wont be required.
Thanks Fred, this project is similar to the first (Dragon Wing) in that I am working outside. I now have the frame stripped for final cleaning and paint. We have had some unseasonably cool weather but it is supposed to warm up a bit next week so maybe I can scrub it down without getting pneumonia .
Yes! It feels so good to see another build under way.
Looks like the wiring harness has been removed. I was wondering what you might do with the Aspencade digital dash, but I guess you get to do whatever you darned well please because it's a pretty clean slate there. (I've leaned away from the Aspencades, specifically because of that dash - even though it's probably fairly simple to bolt on the Standard or Interstate gauges and snip some wires.)
I'm looking forward to seeing where you take it.
In the Stable and Ridable
1978 CB550K - son's cafe
1972 CB500F - recently acquired project on tap for winter '25-6 FrankenWing - 1980 GL1100 motor in 1982 or 1983 frame (still deciding, so maybe semi-active).
The strip down is now complete and I have been working on degreasing and cleaning. This frame is in really good condition but I have decided to repaint both engine and frame with acrylic black enamel. There doesn't seem to be any drag or play in the swing arm so I opted to not remove it. The gas tank will need to be cleaned and sealed on the inside but the outside will get paint along with the frame. Steering head bearings are good and will be fine with new grease. The BIG problem on disassembly was a frozen brake petal. It required almost two hours of hammering and grumbling. Thankfully the tank and rear wheel were not in the way. No damage but I had to drill a new hole for the retaining cotter key as the swing arm prevented me from clearing the old key hole. Tomorrow I hope to do the final washdown and paint on Saturday. The afternoon temp is supposed to be in the mid 70s.
The belt covers and head covers are aftermarket and will be replaced but for now I will paint the belt covers with bed liner to conceal the rust pits. The head covers are not in bad shape but I will try to polish a spare set of OEMs that came with the bike. The intake tubes are really rough but I will try to polish them out. The belts will need to be replaced. I got a new fuel pump and a new car type coil of indeterminate origin with the bike.
"Looks like the wiring harness has been removed. I was wondering what you might do with the Aspencade digital dash, but I guess you get to do whatever you darned well please because it's a pretty clean slate there."
Actually I was mistaken, this was an Interstate model. Because it was already partially stripped I thought it was the Aspencade but you are correct, the gages are conventional mechanical. It even has the 150mph speedo instead of the Carter era 85mph version.
Easter wrote: ↑Wed Dec 06, 2023 9:53 pm
I should have noticed on the photo. I didn't look closely. The 150mph speedo is nice. I put one on my '82 just because I couldn't stand going from a 150mph on the '83 over to an 85mph. Not sure what happens to a speedo that spends a lot of time buried at 85. Up here in Maine, 80-85 is about where you need to be to roll with traffic on I-95.
The tach on the 83 also has a purple "overdrive" light where the air pressure warning light went on the earlier GL1100s, which is pretty nice at night. You'll see that soon enough - unless you disconnect the hookup or there's something amiss.
Yesterday was paint day in spite of high winds (20+). I was able to block the wind and the paint turned out OK. Wouldn't win any contests but looks fine to me. If you can paint one of these frames without missing anything or getting runs it will pass inspection. Today I started reassembly. Still a lot of cleaning and painting of misc. components but it's a milestone when you start putting the stuff you took off back on.
-Rodger- all it takes for evil to prosper is the want of a few good men to do nothing-Edmund Burke The question is not how much time do you have, it is what you do with the time that you haveGandalf "One of the greatest dignities of humankind is that each successive generation is invested in the welfare of each new generation." Fred Rodgers "it takes 10,000 hours to become an expert" ancient saying
"It's a milestone when you start putting the stuff you took off back on."
True dat …
'13 Honda NC700sa … TNG
yeah, but if only I can remenber... what were we talking about?
rcmatt007 wrote: ↑Mon Dec 11, 2023 9:14 pm
If I can't remember where the part came from I either throw it away or paint it black and bolt it on wherever it will fit.
that is happening more and more.
What was frustrating was putting on and taking off the shelter frame multiple tomes
rcmatt007 wrote: ↑Tue Dec 12, 2023 12:33 pm
That is one advantage for the 1100! All you have to do is figure out how to hold your mouth when you twist the shelter just a few degrees clockwise before lifting.
I got really good at removing and putting back the five bolts
