Lucky Find, (I hope), 77GL1000
Re: Lucky Find, (I hope), 77GL1000
leonardhcross
I have started in on these "gummed up" 1975 carbs. My hope is to disassemble the carbs without destroying any of the components. Using ample amounts of PB Blaster, heat, tapping and patience, I have made good progress. But, the hardest part is still to come. Thanks to Cliff Reynolds for the encouragement and guidance. https://www.youtube.com/watch?v=tsVn9TiojtE
leonardhcross
At 2:35 in the video you will see this image. It shows that on carb #3, the most gummed up of the four, there are two float bowl gaskets. Has anyone come across this before? Is there a likely reason that this was done intentionally. Or, is it more likely just an error by some P.O.?
leonardhcross
Disassembly of gummed up 75 carbs went better than expected. All parts out and no damage. Video #2 shows day 2 and 3.
https://www.youtube.com/watch?v=MMTpMX5N-9A
- NotSoLilCrippseys
Maybe Carb #3 is a good place to store one's spare bowl gasket - just in case one fails catastrophically while on a tour.
More seriously, I can't see why one would do that intentionally. More gasket doesn't give you more to compress for a better seal, as torquing the screws down WILL strip the threads on the carb body. Someone I know all too well has done that before!
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
leonardhcross
I discovered the reason for the second float bowl gasket on carb #3. One of the float bowl bolts was stripped. I tried to sneak by by treating the threads with some blue locktite. I should have known better. With the bolts snugged up as much as I dared, the bowl leaked when I tipped the rack sidewise, I ended up installing a heli-coil and that took care of the leaking bowl.
Well, at least you got it to seal now. Glad it worked.
leonardhcross
Today, I started a new thread on this "Restorations" forum for this project. The title is "First Startup on 77 Project Bike". You can continue to follow this project there.
