Fan thermo switch; is this right? (cheap FIX?)
- taunusrainer
I am very sure Your local Ford or GM dealer can match it up if You show him the fan switch, 8$ is reasonable, 100$ is crazy.
CU
Ray
CU
Ray
1976 GL1000 test mule
1969 Ford 17m 2.3V6
1990 Mustang 5.0 7up conv.
1969 Ford 17m 2.3V6
- jacknj
Ooops. that was misleading.
I meant that the one for my Ford is $8. Not that it's the one that fits in the GL.
I'm haunting the local parts stores now to find one that might work. Someone mentioned that the one from an Escort 1.6l Injected would work. But the one at AutoZone does not have a long sensor like the GL one does.
I'm still looking, anyone else have any idea which one?
- 05c50
I stumbled across a listing for a universal thermstatic switch in the JC Whitney catalog. It says that it's adjustable from 170-240 degrees. I think it's about $20. Might be something to look at.
....Paul
....Paul
I prefer to ride my wing naked,thank you
My wife asked me "How many bikes does one man need?" My answer "Uhhh.just one more"
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- taunusrainer
It has to be the right thread and the right switch temp, nothing else matters.But the one at AutoZone does not have a long sensor like the GL one does.
Guess it would be quite a business to offer machined adaptors for the 8$ Ford switches...
has this oneJC Whitney
http://www.jcwhitney.com/autoparts/Sear ... rchbtn.y=0
but it won't fit into the thermostat housing
CU
Ray
1969 Ford 17m 2.3V6
1969 Ford 17m 2.3V6
- alan hawke
- My Album: http://www.ngwclub.com/gallery/v/wingmans//alanhawke
reading up on them
Honda seem to use the same switch on more then the goldwing. Once I look it up in a online parts cat and it was the same number from 75 to 87 goldwings. I forget which other Honda's used it.
Anyway great info from the car guys because I ve been asking for years and no one seem to know if any car ones would work.
Went and bought a used one for 25 bucks.
- octane
Re: reading up on them
The following Hondas use the same switch:tyring59 wrote:Honda seem to use the same switch on more then the goldwing. Once I look it up in a online parts cat and it was the same number from 75 to 87 goldwings. I forget which other Honda's used it. .
Da' Supercharged Bulldog
Antoine de Saint-Exupery
I bet honda charges the same thing regardless of the model.... but it isn't only mother-honda that scr3ews you parts... I needed a thermostat for our saturn car once.... nobody, except saturn, made that kind of thermostat $$$$$
It took a while but I finally got the bike running again and can finish this thread. I don't think that I'd do it again like this but it works and I'm pleased.
I did some research and got indications that a fan switch from a Geo Metro, 3-cylinder (1.0L) matched the threads and temp rating. I couldn't get one locally so I found the part on RockAuto.com for $8.23 + $6.29 shipping. Click the Part Number Search tab and put in the mfg. and number.
Details:
1994 Geo Metro 1.0L 993cc 61cid L3 TBI
Radiator Fan Temperature Switch. Mfg: Beck/Arnley, Part# 2011614.
(I see they're offering the closeout switches even cheaper now.)
The Geo switch does not have the long probe that goes into the thermo housing. It also has a different connector. So I fashioned a pigtail from 4 inches of wire and bullet connectors. Then I shrink-wrapped it all and stole a black rubber foot off grandpa's cane and here's the finished product.
[attachment=0]geothermo.jpg[/attachment]
I couldn't find any specs on what wire is which so I just chose one side to be green and one side to be white/red (I think those were the colors). I figured if it didn't work I could switch them.
Amazingly, it works! Fan comes on when it should and all is well.
UPDATE: Though this switch worked I ended up replacing it with an OEM switch (about $80) when I later replaced the water pump and head gaskets.
Details:
- WingerDave
- My Album: http://www.ngwclub.com/gallery/v/wingmans/album225/
Just a little bit of info..............
The fan switch off of a 1980 Honda Civic is the same range and, basically, exactly the same unit BUT..... a smaller thread (2mm smaller). It's also about a 5th of the price. One way of commanding a high price.
The American Escort was built on a Mazda 3 chassis (as was the Australian Mercury and a few other cars of that period) Talk about Globalization !!!!.
There are even Nissan Bluebirds from the late 80's with BMW front suspension....... problems with supply between Japan and the assembly plant in England.
Dave.
Dave.
If it ain't broke, don't fix it.
'80-'81 GL 1100 Hybrid Vetter Interstate 90K km
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
1980 GL1100 (frame went to current bike, rest parted out)
1983 GL1100 Interstate
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
or put things like light switches and windsheild wiper switches in the sma eplace.... naw, would be to easyRoady wrote:
Wouldn't you think it would be easier if more mfg's used the same parts to do the same jobs.
- RB
Not to high jack the thread but..a PO permanently wired the fan tot eh ignition somehow so it comes on where I turn the key on to start the bike. I'd like to put a switch in the wire so I can at least turn it off when starting the bike. What I need to know is where the fan wires hit someplace easy to get to on the frame so I can wire in a switch and place it in a handy location.
I figure I can cut in anyplace to do this..but having trouble tracing/finding the fan wires..I can see them coming out of the thermo unit but they disappear behind that metal sheet behind the radiator..when do they come out????
This is on an 80 1100
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- AttilaB
