Sounds pretty workable for what is being accomplished with the Arduino. And tweaking things like this are right up my alley. PM on the way.Wolfie666 wrote:there are 330 lines of code, if you PM me your email address I will send it to you.bigscheaf wrote: That would be awesome! And no worries, I’m not a programmer by day either, but I can be dangerous.
I’ll have to dig on cb1100f.net and see if I can find the other post. Might be able to share some additional insight from the inline 4 side of the house. Should be fairly similar between the two platforms for the speedometer and tachometer.
1985 GL1200 Limited, time for a new project.
Re: 1985 GL1200 Limited, time for a new project.
- Wolfie666
C5 Ignition is meant for the left cylinder head, but my FI engine has it on the right, so a little machining to the OEM housing to use for backplate...
- Wolfie666
Mounted...
Also made and mounted a 40A Circuit Breaker...
- Rednaxs60
That is one good use for the old Gr/Gl cam (PG) sensor placement from the CFI system. Ready made and don't have to do too much work to use. Nice job.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
My ten gallon hat is off to you!
- Wolfie666
Wiring the Denso Coils...
- Rednaxs60
Good COP install. Can you provide more info on the COP units you selected?
Ernest
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
- Wolfie666
Sure,Rednaxs60 wrote:Good COP install. Can you provide more info on the COP units you selected?
2003 - 2006 Honda CBR600RR
Can get them on Ebay fairly inexpensive, and the harness usually comes with it,
but I prefer to make my own instead of cutting and splicing.
The connectors can be found there as well by searching for...
6 PACKS Pencil Coil Connectors Terminals For Honda CBR600RR/F4I Yamaha R1/R6
- Wolfie666
Finished!
Sort of...
Have to attend to a few details and iron out some bugs...
Sort of...
Very nice!
- Rednaxs60
Ditto! Very Nice
Ernest
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
- Sugs
And how loud are those pipes!
_______________________
'79 Honda GL1000 Goldwing
- Buli
- Wolfie666
I have 12" steel baffles in them, and the Webers are louder, unless you really get on it,Sugs wrote:And how loud are those pipes!
so they are coming out!
Very sharp ride. Good work. BOM material.
