FWIW, the day before I put Mr.H into storage I drained the tank and the next day I rolled it out of the garage, fired it up and drove it around the house to the storage shed in the back yard. Once in the shed I let it idle for a couple of minutes until the engine started to stumble, then opened the throttle to get it to burn what remained faster. When it stalled I stuffed a rag under the carbs on one side, opened the drain screws and while the remaining fuel dripped onto the rag I removed the battery. After that I closed the drains, moved the rag to the other side and repeated (this time taking the cover off of the air cleaner and putting a plastic bag across it and the cover back on (to discourage critters from taking up residence in the filter) while they drained.
I do that every year and while the rag always gets wet it is never dripping wet. It has become a bit of a tradition to burn the rag in the middle of the driveway when I'm done (it never lasts long).
Any Way to Drain Carb Bowls w/o Making a Mess?
Re: Any Way to Drain Carb Bowls w/o Making a Mess?
- flyin900
See I am not the only guy who uses “Pampers” as a drain medium…thanks Bob. I’ll have to try the “flaming undies trick” on the next batch
Congrats on sidecar of the month.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
I've used aluminium foil before, just shape to fit....
- Sandy
I cut the bottom of a plastic container to fit under the carbs then use a syringe to suck up the gas before it over flows over the edge of the tray.
Thanks.
Pampers? I just use whatever rag is on the bench, preferably one that's about due to be replaced.
- flyin900
I know just my silly sense of humour.Sidecar Bob wrote: ↑Fri Dec 02, 2022 5:47 pmThanks.
Although, I am thinking the adult incontinent version ones maybe better than the Scott’s blue shop towels. Probably cheaper, as those Scotts ones are getting pricy these days.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
I keep a big box of worn out clothes in the shop. That's even cheaper.
