Painting for dumbies....
I do need to clarify.... when I said "sand" I did not mean SAND to remove material.... rather just barely float the 1000 grit to take off the edge between the two base coats and any other "bips" sticking up in the paint
now to apply the "second" part.... this is a colored transparent lacquer.... this is gone over multiple times.... up and down and back and forth so as to get a nice even coat.... put this on to deep too fast and you will end up with a blochy job. you can see that by having a silver and blue base cat, I get two colors as this is laid down
now for the decals... I got these off flea-bay... get some soapy water and lay this under the decal area so you can float the decal... lay it out where you want it.... there will be some bubbles especially where it lays over a rounded surface.... using a soft rag work this smooth.... putting this outside where some sun warmed it while I did this helped
the pin stripping is cal-strips as you work around the curves do not "strech" it, but gentle lay it around. notice how the pin stripe really highlights the two-tone effect
this will sit for several days before the top coat
Got it. That's called "color sanding"....when I said "sand" I did not mean SAND to remove material.... rather just barely float the 1000 grit to take off the edge between the two base coats and any other "bips" sticking up in the paint...
The results are beautiful.
Pretty damn impressive!!!
- Cookie
- RIP: 1950-2011
here it is now with a coat of urethane.... you cannot see in the picture, but a couple of little dusties got in (urrrggggh
I will actually let this sit for some time, and then lighly sand and recoat getting a nice thick clear coat.... all and all I am very pleased with how it looks
- WingerDave
- My Album: http://www.ngwclub.com/gallery/v/wingmans/album225/
You should be pleased........ Shout it from the roof tops
Mighty fine piece of work.
Dave.
Dave.
If it ain't broke, don't fix it.
'80-'81 GL 1100 Hybrid Vetter Interstate 90K km
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
1980 GL1100 (frame went to current bike, rest parted out)
1983 GL1100 Interstate
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
- Tin Member
Excellent!
And I thought that I was the only one with insect marks on a perfect paint! There is only a 9.5 - remember that, and plan results accordingly!
Mantra: "Hahah, you wrecked it! Never should have checked it! Perseverance in problem solving ensures success because POSITIVE ATTITUDE is a FORCE MULTIPLIER!
- Larrycole
Paint Layers
Did I understand that you are layering urethane clear over laquer? Doesn't that lift the undercoat? I've had a terrible time with lifting on plastic parts. I have used an adhesion promoter, but that lifts the rattle can underlayers on contact. I would love to work with laquer base coats with a urethane clear if it works.
07 Suzuki C90 "Brutus"
Another 81 GL1100 standard named "Take 2"
81 GL1100 Cruiser project "80-1-2-3" underway OOPS had to start over
Owned in the past
Numerous Japanese dirt bikes
Kawasaki H-1
96 CB750
86 GL1200 SE-I
70 Triumph Bonne
69 Husky 360
74 Suzuki Water Buffalo[/b]
01 Kawasaki KLR
Owned in the past
Kawasaki H-1
96 CB750
86 GL1200 SE-I
70 Triumph Bonne
69 Husky 360
01 Kawasaki KLR
if you have a urethane over a laquer and then try to put a lacquer on it the urethane will lift.... so if I were to totally redo it I would have to remove all of the urethane before I could paint it
Re: Painting for dumbies....
going to add a tip here.... I recently used Eastwoods plastic narrow tape for blocking off a pin strip. http://www.eastwood.com/1-8-x36-yd-blue ... m-art.html I AM SOLD! There was absolutely no bleed under the tape like you get with plain masking tape. So whether you are wanting a clean edge just between two colors, or laying a stripe (like in the picture below) it is the way to go. It comes in various widths, and in the picture below it is 1/8". However, you can use it to delineate a broader line as in the second picture.
That is some class work, Rodg.
And an excellent tip about Eastwood's tape.
That looks great Rodger. You wanna do mine?
Claude
Claude
