I'm quickly running out of reasons to keep the engine out of the frame, so I figured I'd knock out the few I have left. First off, a little issue I knew I had for a while, but just now got to fixing.
This is the wire for the neutral light switch. At some point somebody decided to cut this wire and splice in a short section of another piece of wire for reasons I'm not entirely sure off. Unfortunately, all they did was pigtail the wires together, then (poorly) wrap the joint with electrical tape. Because I've already replaced the neutral switch, I'm choosing to believe that the switch was the reason my neutral light never went off, NOT because of this wire shorting on the engine.
In any case, that quickly got sorted correctly.
While down there I hit the majority of the surface frame rust with some chassis paint, along with painting a majority of the removable sub-frame. It's not the cleanest of jobs, but nearly all of this will be next to invisible when the engine is in place.
And that's... kinda it. Once the paint is dry I'll do a one-over to see if I forgot anything, then it's time for the engine to get back where it belongs.
