next project - Valkyrie or SilverWing?
Re: next project - Valkyrie or SilverWing?
#31
Those pipes look great.
toomanybikes
#32
Post by toomanybikes »
Fred Camper wrote: Sun Mar 23, 2025 6:16 pm Those pipes look great.
Thanks. There are a few scuffs and dings, but the chrome is very good and overall better than my current pipes.
Asheville, NC, USA
Stable as of 09Oct25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '81 Honda GL1100, '82 Honda V45 Sabre, '10 BMW R1200RT, '16 Moto Guzzi Audace, '78 GL1000
toomanybikes
#33
UPDATE - Maiden voyage/Italian tune ride today of roughly 40 minutes. Ran smoothly and the smoke gradually became less.
It started with blowing smoke at 3k, then 3.5k, etc. By the end of the ride it would only blow smoke if you hit the throttle up to 5k. At that point it's a puff and then clears up.
Oil level is still fine, so it does not seem to be burning oil, at least not quickly.
I'll do another ride tomorrow.
Asheville, NC, USA
#34
Great news, you are close to the finish line. Sounds like the dripping is gone?
toomanybikes
#35
Fred Camper wrote: Sat Mar 29, 2025 5:36 pm Great news, you are close to the finish line. Sounds like the dripping is gone?
Will have to see on the next ride. The tell tale sign was residue on the side stand when it's in the riding position. Wipe clean, ride, check and we'll know. Also, once I swap exhaust we'll know if the smoke was from the engine or residue in the pipes.
UPDATE - One more burn out ride now done. Very little smoke, no residue on side stand, oil levels still unchanged. All good now.
Still need to get the tank fully de-rusted, then she'll be 100%. I did a few tank flushes with PB blaster and then gas to get the loose stuff and sediment out. Now it's time for Evaporust.
Asheville, NC, USA
#36
Good news, she will be a forever bike very soon.
Lucien Harpress
#37
Post by Lucien Harpress »
Good to hear! Valkyries don't really seem to have reputations as maintenance hogs, so it's good that your problems seem to be clearing up.
Now that you've got a bit of seat time, what do you think?
dontwantapickle
#38
Post by dontwantapickle »
They are very dependable bikes, Never let us down.
Only maintance issues I ever had with mine (other than having to replace the petcock once)
was leaking fork seals. I replaced them 3 times in 128,000 miles.
Probably from taking the big heavy bike offroad.
...and I guess rear tires.
I went thru Dunlops pretty quick until I went to the darkside and was able
to do 30,000 miles between tire changes.
toomanybikes
#39
Lucien Harpress wrote: Sun Mar 30, 2025 5:21 pm Good to hear! Valkyries don't really seem to have reputations as maintenance hogs, so it's good that your problems seem to be clearing up.
Well, she's a heavy ride, so low speed handling will take some getting used to. Corners well on the gradual turns of the Blue Ridge Parkway, which is my intended usage. Would be nice if the windscreen was a 2-3 inches higher. Buffeting isn't bad, but it's not perfect either. I have a small extension screen that I'll try soon.
Haven't yet done any of the local tight twisties, but I have other bikes for that. Same with dirt roads, this bike will only ever see pavement unless something has gone horribly wrong.
Engine is super smooth, as you might expect from a flat 6. Ergos are good for me, I like the pegs under foot and can stand up without it being awkward.
I also have a naked GL1100 project that should be done soon. Will be interesting to see how the 1100 compares to the Valk, and if I keep both.
Stay tuned.
Asheville, NC, USA
toomanybikes
#40
UPDATE - Turns out the GL1100 position works better for me than the lower seat position on the Valkyrie, which aggravated my sensitive right hip flexor. Kept the Goldwing, sold the Valkyrie to make room for the next projects ('78 CB750F, BMW R1200RT).
Sorry Valkyrie lovers.
Asheville, NC, USA
#41
Unusual situation for a bigger bike with a lower seat. But we are all built different so hope the Valk sale was not too hard on your wallet.
toomanybikes
#42
Fred Camper wrote: Wed Jul 16, 2025 12:33 pm Unusual situation for a bigger bike with a lower seat. But we are all built different so hope the Valk sale was not too hard on your wallet.
I bought as a non-running project, so the final selling price was about what I had into the project.
Asheville, NC, USA
julimike54
#43
Post by julimike54 »
Long rides should be the answer unless something else is amiss. The PVC is the other culprit to suspect.
By the way you show Asheville, don't be surprised at the end of July/ first of August to see more than usual Roadglides in the area, we're having a get together then.
1986 GL1200A
