Looking at another project 86 Aspy (bought)
Re: Looking at another project 86 Aspy (bought)
#31
Fork seals if required will be easier this time. Not easy, but a bit less of a PITA. Well worth the effort is the film does not work.
ritalz
#32
Post by ritalz »
Small update today. Added a led volt meter. Ebay special was only a couple dollars.
#33
Always nice to know the voltage. I have an LED on bad dog that flashes different colors to show 5 voltage range. Clearwater Sentry I think.
#34
I have a set of 1200 bag locks with keys if they are of any use.
Just shipping
Gord :roll:
ritalz
#35
Post by ritalz »
Thanks but I'm pretty well set for locks on both of my 1200's. Even have another set in my parts box.
#36
OK, open offer … I’ll list them in the 'free' forum
Gord anim-cheers1
ritalz
#37
Post by ritalz »
Another step closer to finish on this one. Sailed through the state inspection. Was having a small issue with the front brake light switch. Easily replaced but noticed a small leak at the sight glass while changing the switch. Sight glass disintegrated and dumped most of the brake fluid. Cut out a new plastic piece and epoxied it in and so far there is no leak. Taxes and license plates for two bikes will have to wait for payday.
#38
Glad you were able to fix the sight glass. Many of us would have swapped out the master. Good for you Al.
ritalz
#39
Post by ritalz »
Well, my sight glass fix was not nearly as effective as I had hoped. It decided to still leak a little bit. I epoxied over the entire thing and that stopped the leak. We don't need no stinking sight glass.
#40
A dime is about the right size …
Gord :roll: anim-cheers1 :8)
ritalz
#41
Post by ritalz »
Another shakedown today uncovered another issue. Fan was not kicking on and low speed running made the temperature go high. Fuse was blown and another fuse blew right ayay. While diagnosing I found the fan to be hitting the shroud and causing the overload. Bent the shroud in the right place and now the fan cycles normally. Front brake is still pretty weak. Bled some more air out of the system. Will test run the brakes again soon. Had to stop to take care of other things.
ritalz
#42
Post by ritalz »
Made a replacement panel. Doesn't have the lettering like the original but it covers the hole.
ritalz
#43
Post by ritalz »
I'm guessing a carb issue is causing it to fart and pop for about the first ten minutes. After it's good and warm that all stops and she runs fine. There is an exhaust leak but pretty far down the line. Right where the header connects to the muffler(s). To date I have not touched the carbs at all since it seems to run good once it's warmed up. I'm busy doing some heavy maintenance on the 1800 so I have time to think about it.
#44
Might be best to just get 3 tanks of fuel though her before considering any carb work. A bit of sea foam may help too.
ritalz
#45
Post by ritalz »
That's the route I've been taking. Weird part is it clears up after riding for just a few minutes.
