My GF's engagement present...sshhh its a secret!
Sagebrush
Re: My GF's engagement present...sshhh its a secret!
#46
Post by Sagebrush »
It helps to get a thin putty knife between the case halves and work it around being careful to not gouge the machined surfaces of the case halves. Once you get it started its relatively easy to work it around. There is no gasket between the halves and there is a sealer between them to keep any leaks from occurring. This sealer (Hondabond or Yamabond) acts like a glue.
#47
Good to know Dean, always helpful.
bottobot
Brass Member
Brass Member
#48
Post by bottobot »
Sagebrush wrote:It helps to get a thin putty knife between the case halves and work it around being careful to not gouge the machined surfaces of the case halves. Once you get it started its relatively easy to work it around. There is no gasket between the halves and there is a sealer between them to keep any leaks from occurring. This sealer (Hondabond or Yamabond) acts like a glue.
That is some good info. Should I find this stuff so I can reapply it when I put this thing back together?
Oldest to youngest:
'55 BMW R25/3 - in buckets | '70 BSA A65L - blown engine | '79 Honda GL1000 - getting rebuilt| '07 Honda CBR125R - Now a 166cc Streetfighter
.........Image..............Image
#49
If you mean the Honda/Yama/Kawbond then yes. That is what you sue to put case halves back together. These days I use ThreeBond Liquid Gasket 1194. Same stuff as all the others. I get mine from Z1 Enterprise. If you have dealer local to you they should have something.
bottobot
Brass Member
Brass Member
#50
Post by bottobot »
Cool, thats a really good tip. Thanks :D
Oldest to youngest:
pierce
My Album: pierce
#51
Post by pierce »
Be sure that all case bolts are removed. There are a couple hidden on the left rear side of the engine that are easily missed.
http://ngwclub.com/forum/viewtopic.php?p=468871#p468871
I use Permatex Ultragrey to join the halves.
This will help with the rings once the case is split. Buy the Hastings.
http://ngwclub.com/forum/viewtopic.php?p=467625#p467625
I am curious when you mention gears 'rubbing'. There really is no way for any of the gears to move at all inside the case so I would be curious what you might be talking about.
If you are splitting the case, you mine as well do some other stuff like installing the 1200 chain tensioner etc. Read through the entire thread if you haven't already, it could help.
1976 GL1000
1978 Gl1000
