The NGW Project Bike. Timing belts. Removal/installation
Locked
dblum
#61
Post by dblum »
I'm going to order belts soon. Question on the Tensioners. How do I know if I need to replace? Don't want to do the job twice.
Never Quit!
76 GL1000 Naked
08 Yamaha XT250 (got to do a little off-road every now and then)
07 Yamaha FJR1300AE (wife's bike)
08 Honda ATV (wife wants to play off-road too)
spin the tensioner without the belts on. if you hear a bearing noise- replace them. feel the amout of play with a twisting motion. if they move, replace them
What doug said. Quiet and smooth are what you want. Spin it as fast as you can with your hand and put it up by your ear. You should hear just a whisper of noise.
dblum
#64
Post by dblum »
Thanks. Doing the belts next weekend. Weather's nice this weekend, so I can't pass up the chance to ride.
Never Quit!
76 GL1000 Naked
jbdetcity
Brass Member
Brass Member
#65
Post by jbdetcity »
Thanks Octane made the job a breeze. Just did mine tonight and she runs great. :-D jb.
JB
75 GL1000 45k
gdurfey
Brass Member
Brass Member
1200 Belts
#66
Post by gdurfey »
I also have an 84 naked 1200, does anyone have the gates belt numbers for the 1200 timing belts??
thanks in advance and great how-to Octane!!!
84 Standard up and going
75 back parked
76 waiting for engine something or another...
05 Rumble Bee 1800
CMA, GWRRA, ABATE, MSF Instructor
anarki
#67
Post by anarki »
GL1200
Gates - #5043 or #T070 (2 ea.)
NAPA - #250070 (2 ea.)
Goodyear - #40070 (2 ea.)
Found in the Cross Over Parts List sticky topic:
http://www.ngwclub.com/forum/viewtopic.php?t=7416
You cannot teach a man anything; you can only help him find it within himself.
Galileo
'78 GL1000, '77 KZ650 Cafe Racer
anarki
#68
Post by anarki »
Just finished doing my belts. Thank you so much for the detailed tutorial!! I never once had to crack my manual open. Awesome info! Thanks again!!!
Galileo
tomahawk
Lead Member
Lead Member
Thank-You
#69
Post by tomahawk »
Did this job today following your instructions and the bike is up and running great.
The only place I differed is I just took the bottom rad hose off and pulled the rad back out of the way. It was a slight nuisance but not to bad
Thanks for the excellent instructions
Tom
Respects
Tom
gritter
#70
Post by gritter »
Talk about a NAKED 'Wing! Got my Faux Tank off, seat, radiator, and timing covers off, and she is really naked. Now, for the fun part - I got the belts from Napa this morning, and she's ready for the big step. I've printed the pdf, and I'm going to go VERY SLOWLY. I've never done a timing belt, and I'm not sure where the alternator bolt is... Wish me luck. Image
Gritter Flash
gritter
#71
Post by gritter »
Okay, what I think was the alternator cover, or possibly the bolt, was some crazy size, between 16mm and 17mm - then I realized I have no idea where the timing mark cover is.
Gritter Flash
Yea that cover has a kind of a tapered cut to it.
The Timing index cover; Look on the left side of the engine on the top of the engine behind the carburators. Just about straight underneath the Fuel filter input. You should see a small cover with a Large spot for a straight slot screwdriver. that is it.
gritter
#73
Post by gritter »
I think it's in the area of the timing belts, I have an '82 GL1100... Oh well, I never opened what I thought I found anyway - I just did it according to the manual, and ended up being one tooth off on the right side... At least it was the right side, so I didn't have to take the ENTIRE thing apart again.
I put it all back together, after turning it with the wrench - to make sure nothing was hitting anything. Well, I heard this LOUD ticking from the right side, and I knew it was the valves. I did the screwdriver to the ear and pressed it against parts of the engine to listen, but I couldn't hear anything that way... Then I imagine the valve seats, slapping the head... I tore it apart (about three times as fast this time!) and moved it one tooth, and it is all back together and awesome again!
It didn't look like my timing belts were THAT worn, but the peace of mind I now have is worth more than what I had to put into it today. Thank you, NGW, for I wouldn't have even known to do that in the first place.
Gritter Flash
wpb1960
Timing Belts
#74
Post by wpb1960 »
Is this procedure the same for a GL 1100 ?
Wayne, 1980 Standard Goldwing, Born Naked !
Re: Timing Belts
#75
wpb1960 wrote:Is this procedure the same for a GL 1100 ?
Yes
Locked
Return to “Octane's Corner”
