How do I repair plastic?
jhusman
Post by jhusman »
I bought some Hondaline suitcase bags and a rack, and they have ne small hole and one crack about 6" long. How do I fix this?
1979 GL1000
Richardson, TX
Bandanna
Post by Bandanna »
you could use fibrefill,or glass reinforced plastic(grp)
dont exactly know what is available in the usa..
here we even have hot melt plastic guns(plastiweld) that melt plastic like liquid glue,in various colours that set like normal plastic........
shop around,you will find suitable repair kit for your needs........
safe riding.....................friend. ;)
Try
NGW Founder
NGW Founder
Re: How do I repair plastic?
Post by Try »
jhusman wrote:I bought some Hondaline suitcase bags and a rack, and they have ne small hole and one crack about 6" long. How do I fix this?
Try Uniplast
Try
"84 - GL1200 Standard
anim-cheers1
Victorious1
RIP: 1954-2015
Post by Victorious1 »
The best way I've found to repair ABS plastic parts is use cut off sections of ABS plastic pipe and fuse them into the cracks or holes with a large slodering iron that I have, then I can just about make an invisible repair.
This is called plastic welding and all plastic must be clean and the plastic temperature must be controlled precisely so it does take some practise.
If you don't have the skill or tools neccessary to do this you can go to most auto body shops and have them do it for you.
Vic
Dice
Brass Member
Brass Member
Post by Dice »
Everybody has great idea's, and I've done most of them, and know they work.
One other not: drill a hole at the end of the crack, so it won't continue to split after repairs.
whitehog69
fixing plastic holes or cracks
Post by whitehog69 »
I used to work for a company fixing and respraying business telephone systems. They would come to us after a fall from a desk or what have you. To fix cracks or to make new corners ect... we would use superglue and baking soda put the superglue into the crack then while it is still wet sprinkle baking soda on it . It hardens that sec and is very strong. then it can be sanded and painted. Hope this helps someone.... :lol:
jhusman
Post by jhusman »
Not bad, I'll have to try it. I have been away from the wing for a while because I bought a 72 Honda Trail 90, and I've been trying to get it going.
1979 GL1000
Richardson, TX
