I'm buying some dogbone risers so I can put a drag bar on - are the regular bars wired internally? Do I need to find some hollow bars? If so, how does that work?
Thanks,
Justin
Are GL1000 Bars wired internally?
1979 GL1000
Richardson, TX
Richardson, TX
- quakeholio
- Tree
- Zinc Member
- drmudd
I wired my bars internally; it cleans up the view from the saddle!
http://www.ngwclub.com/gallery/drmudd/handlebar
- QUEEENlE
..here is the pic
Hope this helps. Ohhhh.....Fixing the link worked ..hahahaa ...sorry
Hugs
Q
Hugs
Q
- Dougal
The wiring on the KO/K1 and K2 100te0 models had the switchgear wiring wired internally in the handlebars. This prctice was quite common on Honda's until the mid 70's. To change this, you have to file a slot in the switchgear to allow it to be wired externally to the bars.
Honda stopped this parctice with the GL1000 K3 or KZ models onwards.
Dougal
Dougal
They say WHY?, I say why not.
