Here are some fork mounted lights. Think you need the 41mm size. About $ 45 US for a set of two. I couldn't figure out how to get a pic posted.[/img]
83 GL 1100 bagger Ugly Betty ALL WE WANT TO DO IS DRINK OUR ESPRESSO, RIDE OUR MACHINES, AND NOT BE HASSLED BY THE MAN Owning a motorcycle is not a matter of life or death. It's much more important than that. "Don't sweat the little things, guys, take care and appreciate all that you have around you!" - Fewman NGWclub on Facebook
Yes deafinately Brant . Go for it . Looks like the mounting tangs could match up or with little modification . Good luck with getting it . I really like those fork mount signals also .
Congrats AB , I see you can simply make up a braket with the proper centre holes to match with the front brake crossover on the GL . Dang they look good though .
Zryder wrote:Congrats AB , I see you can simply make up a braket with the proper centre holes to match with the front brake crossover on the GL . Dang they look good though .
Thanks Zryder, do you think the bolts should be longer to provide the same strength to the mounted parts??
Those bolts you may want to get them a bit longer just to make up the thickness of the material you are using is all ., yes for that . I mounted my aftermarket headlight pod on it and am very satisfied of the quality . What I think I'll go ahead and do is fabricate the same type of light bar you got there out of stainless steel and weld it to my braket I have the headlight pod to . Thanks for the idea . Hummmm , to the drawing bourd all .
Nice light bar there AB. I would have liked to have that.
What I think I'll go ahead and do is fabricate the same type of light bar you got there out of stainless steel ?
Z- you gonna make one? Have you got a tube bending machine, or how you do the bending ?
