CX500 kicking my #$%& water pump leaking
mrbswing
Post by mrbswing »
I have my gun loaded and ready to unload it on a 82 Honda CX500 that was peeing out the weap hole on the water pump so I replaced ALL the seals that were there and it still leaks :evil: so what the sam billy hell is going on here? :twisted: I thought I had it licked when I used some of lube seal which did stop it till I took it for a ride and when I got back home it was peeing all over the place??? I AM CLUELESS AND PISSED off to say the least....HELP BEFORE YOU HEAR LOUD RAPID FIRE. till then 8)
Mr Bill
(2)77 wings,two 83 wings 76 CB550 bobber,80 wing,CX500 turbo,700 Nighthawk,2 750 Yamaha triples,80 XS1100 yammy,CB360,600 yammy,CB750 s/s,and a few more? and my main bike(a beautiful 79 XS1100 Yamaha 19,000 miles) and it is very fast! Got another bike a 84 1200 Yamaha I think its a 1200? and more coming. Till then :8)
"DON'T TELL ME I AM WRONG UNLESS YOU ARE RIGHT"
I have no idea but it is good to see you back. :-D I was beginning to worry. Had not seen you post in a long time.
Q
Post by Q »
A couple things to check.
Radiator cap, have it pressure tested. Most auto parts stores should be able to test it for you for free.
Copper washer at water pump impeller. Should be replaced or annealed before reinstalling. Sometimes a leak there can be stopped with a bit of Bars Leaks or equivalent.
I've seen new ceramic water pump seals leak for a while before sealing, but usually just a slight leak.
Q
QQQ
mrbswing
Post by mrbswing »
Q wrote:A couple things to check.
Q
so if the cap is bad will make the pump leak?
Mr Bill
mrbswing
Post by mrbswing »
Whiskerfish wrote:I have no idea but it is good to see you back. :-D I was beginning to worry. Had not seen you post in a long time.
Just been really busy trying to get something done so I can sell it? so I was just getting this piece of crap done in hopes of getting it up for sale and it just keeps peeing :roll: so I think I'll get it a diaper or several rounds of 380cal bullets ;) thanks for being concerned..till then 8)
Mr Bill
Q
Post by Q »
If the pressure cap is not releasing it can push coolant out the seal.
Q
Q
QQQ
mrbswing
Post by mrbswing »
Q wrote:If the pressure cap is not releasing it can push coolant out the seal.
Q
Q
so check the cap and replace the copper washer is what u r saying? would it help if I put some sillycone on the washer?
Mr Bill
Q
Post by Q »
Yes, pressure test the cap and replace the copper washer. Do not put silicon on the washer. Make sure there are no burrs on the acorn nut or surface of the impeller where the copper washer seats. Be sure not to over tighten the acorn nut.
Q
QQQ
mrbswing
Post by mrbswing »
Q wrote:Yes, pressure test the cap and replace the copper washer. Do not put silicon on the washer. Make sure there are no burrs on the acorn nut or surface of the impeller where the copper washer seats. Be sure not to over tighten the acorn nut.
Q
sounds great will do the above and get back with the results later today. thank you..till then 8)
Mr Bill
1CrazyMoFo
Post by 1CrazyMoFo »
You may want to check with RoadKill and see if there are any feminine hygiene products that are small enough to stop the leak. :lol:
Or you could just fix the damn thing.
But if you decide to shot it, we want video!!!
Peace,
Frank
The truth about Ape Hangers, yes they are very slimming.
mrbswing
Post by mrbswing »
1CrazyMoFo wrote:You may want to check with RoadKill and see if there are any feminine hygiene products that are small enough to stop the leak. :lol:
Peace,
Frank
I did fix it thats the problem :cry: I replaced ALL the seals there is nothing I didn't replace. :twisted: :evil: till then 8)
Mr Bill
mrbswing
Post by mrbswing »
Q
I didn't get around to it last night I got side tracked when I went to put gas in my bad ass XS1100 special and a guy at the station asked if I knew anyone that might want to buy a XS1100 standard? :-D and of course I had to go look at it, well long story short I just added to my family one 80 XS1100 standard so I never got around to it. I talked to a cronny of mine and he has had the same problem with those fricking CX500s and has come up with a permanent fix that is the best idea I have ever heard :) no its not blowing it up..stay tuned for pics later tonight.till then 8)
Mr Bill
mrbswing
Post by mrbswing »
Peace,
Frank
pixs coming as soon as I remember how to do it..till then 8)
Mr Bill
mrbswing
Post by mrbswing »
Peace,
Frank
OK pixs under how to train your cx500..and it works let it pee any time it wants..GOT YA you dirty rat CX500 :twisted: till then 8)
Mr Bill
