tire for gl 500 ,,,140 /90/16
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
Will a Dunlop Crusemax Whitewall 140/90/16 fit in place of a MT 90 /16 ?? Looks tight to me . , I mean it looks like there is more clearance on the left side than the right .
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
Re: tire for gl 500 ,,,140 /90/16
It's supposed to be a 130/90-16.
Some brands of 140 might fit (the only dimension that's consistent between manufacturers is the diameter at the bead) but the only way to know for sure is to try it.
If you need a rear tire you can also consider swapping in an 18" CX500 wheel with a 120/90-18 tire. The RPM will be reduced by about 5% with similar mileage improvement. And the handling will be a bit sharper with the 120.
Depending on your intended use you might even be able to buy a CX wheel and a suitable tire for less than the 16" tire (especially if you need a tire with some knob and you don't like Bridgestone Trail Wings).
The only negative is that the CX wheel will be a silver Comstar instead of a black reverse Comstar.
