here is a great fitting ford starter sol.
this starter sol. fits great under the left lid ,,a little filing of the two in. hole ,,slip it in from the air filter side,,one bolt to hold it ,,,gives aplace to hook up your coil "hot shot",,for great starting,,,stock air filter fits back fine.
1975 wing
Re: here is a great fitting ford starter sol.
Cool, what's the cost on that little puppy?
Can you share a pic of it installed?
I believe this can be bought at autozone for $9.99,,thier PN is F491
1975 wing
"gives aplace to hook up your coil "hot shot",,for great starting,,,stock air filter fits back fine."
What's a "Hot Shot"
Gord (Still learnin') Jones
What's a "Hot Shot"
"Hot shot",,giving your ign system full voltage while cranking the engine,,the engine normally runs on reduced voltage because of resistors,,makes starting better
1975 wing
here it is from the inside
1975 wing
here it is from the front,,this is used on a totally rewired 75
1975 wing
nice, and thanks!!
