CX500 vs GL500
CX500 vs GL500
Besides fairings, bags and trunks, what are the main differences between the CX500 and GL500? I will be taking delivery of a 1982 GL500 in the next day or so.
Thanks,
Steve
Thanks,
Steve
StevenM
1978 Honda GL1000 "Scrap Iron"
2006 Kawasaki 1600 Nomad "Black Pearl"
1997 Yamaha 535 Virago "Mini Pearl" (Hers)
2008 Piggy Backer Cargo Trailer, "Sold..sadly.."
Re: CX500 vs GL500
I think the basic bikes are the same, just the plastic.
- My Album: http://s325.photobucket.com/albums/k378/LRCXed/
Re: CX500 vs GL500
There are some differences between them. The frame has 3 upper frame tubes from the steering head back, vs the single back bone tube on the cx.
The carbs are closer together as a result of the frame design. And the primary drive gear is a 34 tooth vs the 33 tooth of the CX. This lowers the final RPM's by a few hundred rpm at the same speeds. I think the flywheel and starter clutch is different too. But I haven't seen one myself to be sure.
Also the rear suspension is a single shock Prolink type vs the twin shock of the CX. And the front forks are set up with air assist and have a bit heavier springs inside. Finally, the ignition system is a transistorized system vs the CDI type of the CX. The stator does not fire the ignition system. It only charges the battery.
I forgot one thing. The Gl500 has an electric fan too.
If your going to do something, Do It Right, Don't do it half A*"ed"
Re: CX500 vs GL500
Or not .... if I were you I'd listen the the 2nd guy.RAT wrote:I think the basic bikes are the same, just the plastic.
He actually KNOWS what he's talking about.
Gord (Thanks Larry) Jones
Re: CX500 vs GL500
Thanks guys, (That includes you, Gord) that's what I was looking for.
Steve
Steve
StevenM
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
Re: CX500 vs GL500
I thought the 650 only had electric fan ??
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
- mildhog
- Zinc Member
Re: CX500 vs GL500
You're right. The GL500 has the shaft fan.the chef wrote:I thought the 650 only had electric fan ??
Arnie in VA
In the stable:
81 GL1100, 82 GL500I, 83 GL650, 81 Gl500I, 82 GL500
In the stable:
Re: CX500 vs GL500
I just worked on an 82 a week ago that didn't seem to pass any air over the motor while it was running. I assumed it was electric as I don't have a GL500. I have the GL650I. I guess I better get him back here and see if his fan has exploded. Thanks for making me look it up on the parts listing. I was wrong. Sorry!
- Lead Member
Re: CX500 vs GL500
There are more differences than similarities between the mechanics of the CX & GL engines and bikes. The differences are:
.Frames
.Motor mounts
.Carbs
.Brakes
.Frame
.Suspension systems
.Ignition systems (except the last year of the CX)
.Forks
.Lights
.Bodywork
.Flywheels
.Stators
.Rear engine covers
.Radiators
Just to name some of the major differences. They do share some engine parts and tire sizes (except the 78) and that is about it.
I hope this helps you out.
.Frames
.Motor mounts
.Carbs
.Brakes
.Frame
.Suspension systems
.Forks
.Lights
.Bodywork
.Flywheels
.Stators
.Rear engine covers
.Radiators
- Zinc Member
Re: CX500 vs GL500
And weight too, GL is heavier, my 81 GL seemed to handle quite different than my 79 CX which almost seems "flickable"
in comparision. But as mentioned by David and Larry the suspension and other components do make the bikes different,
albeit only marginally.
Rick
Rick
1978 GL1000
1979 CX500 C
1979 CX500 C
Re: CX500 vs GL500
The cx650 also had The heavy crank and bearings that were used in the 650 turbo, making it a really bullet proof engine.
- Lead Member
Re: CX500 vs GL500
There is nothing special about the 650 engine's crank over the 500.
The difference between the GL/CX650 and the CXT650 is the oil pump output, clutch and the gearing is really different. That goes without saying the fuel injection too.
The 650T also has a lower compression to handle the added pressures of being turbo boosted. It is actually slower than the CX/GL model until the turbo kicks on.
The CXE model in both the 500 and 650 had electric fans in Europe. I don't know if it was the same in Canada and down under. the only models with electric fans in the USA were the CXTs and all the 650s. All 500s in the USA were equiped with mechanical fans.
Re: CX500 vs GL500
Good info. THe Honda mech down the street seemed to think the crank had been beefed up, but you know those mechs...
