SDS-EM4 stand alone EFI on Goldwing?
earthquake
Post by earthquake »
Has any body ever tried to use a automotive based stand alone EFI on a Goldwing, I have a complete system I bought for my old Datsun 510 but never got around to using it.
http://www.sdsefi.com/index.html
I don't think it would be to hard to make work, the system is very tunable and with the right injectors and throttle body it should make some good power.
Casey
"If it shines, bends, bangs or clangs, ITS METAL!!! and if I cant work it, I"ll piss on it!"
I love Boxer engines be GoldWing or VW
http://www.rememberingkelly.com/
Dangeruss
Re: SDS-EM4 stand alone EFI on Goldwing?
Post by Dangeruss »
Mmmm, Datsun 510. I had two of them, a '71 2 door and a '70 four door I drove the pants off, sweet cars!
Sorry can't answer your question, just waxing nostalgia. ;)
Russ
2016 K1600GT
75 GL1000 Project
States visited by Goldwing...
earthquake
Dangeruss
I had it the other way around, 71 4 door and a 70 2 door. The 4 door had full coil-overs and camber plates and a healthy L16 that would turn 8000 rpm, I miss them, now I'm into air cooled VWs and Goldwings
Casey
FirstYearDeek
Post by FirstYearDeek »
Not familiar with that system but as long as you can program the fuel and spark tables, all you have to do is get the right sensors and flow rate on the injectors.
The "lean/rich" knob kills me... might as well hook it up to the accelerator.
-Deek
socrace
Post by socrace »
Mounting a crank trigger will be a pain, if your SDS needs it.
There's basically no room at the front (unless its a 1200).
The rear has more room, but have to pull the swing arm to get to it.
Going to be mounting a 36-1 wheel at the rear of mine, after riding season is over.
Bob D
Very interesting.
Oldewing
Secretary
Secretary
Post by Oldewing »
Dangeruss wrote:Mmmm, Datsun 510. I had two of them, a '71 2 door and a '70 four door I drove the pants off, sweet cars!
1969 Wagon, and my First car dancr dancr dancr hand me down from my brother(Not RAT).
PsRumors
Post by PsRumors »
If I were going to take the time to FI a wing I'd look to mega-squirt. SDS equipment is has more pieces, is a little older equipment and doesn't have near the support as mega-squirt. Of course you already have the SDS so it makes it a tough decision.
