replacement shocks
jkgoldwing
Brass Member
Brass Member
replacement shocks
Post by jkgoldwing »
Good morning, i have a 1983 honda goldwing interstate. i am getting ready to go in deep and do a ton of work. while in there i wanted to replace the shocks in the back. they are air suspension. i would like to replace them and not rebuild them. does anyone have any suggestions? i am a big guy and with a rider she bottoms out easily.
j
1983 Honda Goldwing 1100
Re: replacement shocks
I think for a bike with a significant load about the only thing I would recommend is to rebuild the stock system or replace with Progressives. Progressives are not cheap but they do work well. Also might want to try using the search function. We have had literally hundreds of discussions on shocks. I am sure in some of them there are recommended Vendors.
Gonna move this back to the tech forum so it will get some additional inputs.
I put Progressive's 412s on the Fat Rat, I'm 220ish and they are still on the lightest setting.
Never hit the bottom yet.
Oldewing, my LITTLE brother has them too.
jkgoldwing
Brass Member
Brass Member
thank you and sorry about using the wrong forum...
Sagebrush
Post by Sagebrush »
Can't go wrong with progressives.
Jack the Dwarf
My Album: http://ngwclub.com/gallery/v/wingmans/Jack+the+Dwarf
Post by Jack the Dwarf »
jkgoldwing wrote:Good morning, i have a 1983 honda goldwing interstate. i am getting ready to go in deep and do a ton of work. while in there i wanted to replace the shocks in the back. they are air suspension. i would like to replace them and not rebuild them. does anyone have any suggestions? i am a big guy and with a rider she bottoms out easily.
j
Try looking for hagon shocks...... They make progressives for low budget but great look... I bought the chopper version. You can give tgem your weight and they will set up the shocks right for you with NO extra costs also shortening is possible with no extra charge
Jack the Dwarf
Ride bald and ride proud
GL1100 SC02 1980 or 81 or 82 US-Model. Bought as a new bike by my grandpa in '84 and in the family ever since
scootsx2
Post by scootsx2 »
+1 on Progressives or Hagons.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
MJSWingman
Post by MJSWingman »
I'm in the same place in my rebuild. Has anyone with a GL1100 tried these?
http://www.ebay.com/itm/HONDA-GL1100-GO ... es&vxp=mtr
Thanks
Mike
1983 Standard- Undergoing An Enforced Diet Towards Nakedness!
Tugboat
Post by Tugboat »
I can't speak for these specifically, but I do know that all of the new low-priced shocks for the SOHC CB750 on ebay are crap. For the most bang for your buck, go with the Hagons. Call Dave Quinn in Connecticut - he's their US dealer. As stated above, he'll ask your weight, passenger weight, etc and get you a perfect fit. I'm getting mine for about $270 for the pair shipped.
http://www.davequinnmotorcycles.com/
1976 CB750 F1 w/ '77 CB750K motor
1976 KZ400 D3 w/ '75 KZ400S motor
1973 TL125
1974 TY250
1981 C70 Passport
1983 GL1100 (sold)
Anything worth doing is worth doing twice.
Easter
Post by Easter »
If you want to go cheap, Try to find a good set from A Yamaha 1100 touring bike. I have a set on Dragon Wing and they seem fine. Quite firm but not jarringly so. Single rider 190 lbs. I am sure they would be fine with two riders. All that is required is to remove the chrome insert from both top mounts and one bottom mount. A Drill press will do the job (the heat of drilling will cause the insert to fall out of the rubber) Some metric sized washers will fill up the extra space.
83 GL in process :IDTS:
BusaRider
Post by BusaRider »
I used V-rod take offs. They were cheap. They are very firm, and are adjustable. The right side is plug and play. The left side requires the bottom mount to be massaged a little...
'81 GL1100 - Café with a Twist * 1990 Suzuki GSXR-1100
2000 Triumph Speed Triple * 2016 BMW F800GS
2013 BMW S1000RR * 2017 Harley Davidson Heritage Classic
MJSWingman
Busarider- thanks for your input. Could you expand on the "massaged" work required for the left side.
Also, do you feel the V-rod shocks would be too stiff for one-up riding on a naked?
Thanks,
Mike
Patriccio
Post by Patriccio »
I bought a set of YSS shocks for my 80, but I've not ridden it yet. The shocks appear to be high quality & adjustable. I may have to add inserts & washers for the correct fit.
Red2trike
Post by Red2trike »
Yeah, busarider.........explain massaged!!! Interested myself and they do look good on the bike set-up. ;)
RT2
