Can I run '79 carb rack on my '77
- klux182
- Tin Member
I just bought the 77 to replace the "locked-up" '79. The 77 has been sitting for 25 years. I want to use my "working carbs" from the 79 on the 77. I will deal with the original ones later.
Re: Can I run '79 carb rack on my '77
Should work, but not as well as 77's. Rebuild them taking your time and you'll be happier. Read Randakks blog on mixing them.
- klux182
- Tin Member
ok...Thanks
- klux182
- Tin Member
..had the old carbs rebuilt. I just dropped a washer down the intake, so off comes the head. Geesh.
Magnet, vacuum?.
- gregforesi
The 79 carbs are jetted slightly leaner and have slightly smaller bores to work with the later cams.
Regarding the washer..I suppose turning the bike upside down and shaking it is out of the question?
2006 GL1800 (Brutus Maximus)
