Most of the time I am in the later group as I consider fueling up as at best a reduction of the fun I am having.
All of my running Wings are tuned pretty well and they make me smile broadly when I head out to some twisties somewhere. My favs are the Tail of the Dragon on US129 in Tennessee/North Carolina or Cherohala Skyway in NC/TN. So its either 2nd gear high rpm on 129 or a higher gear @ considerably higher speed on the Cherohala. My consideration for mileage during these times is a non factor.
I did a tune up on my Pennie Lee this AM and took her out for a spin to check her out. I wanted a little interstate run as well so I hopped on I-40 west and immediately was presented with a 9% up hill grade. Once I got to speed, I stabbed 5th gear and rolled on the throttle. Noticing that I had to keep the throttle on more in order to maintain the speed, I did as I normally do, I put her back in 4th. The thought hit me that 4th gear may be more efficient at maintaining this speed than 5th. Like most guys having a blast, mileage (efficiency) had usually not been an issue.
I stopped up the road just a little way and purchased a bottle of yellow fingernail polish. (Don't tell my wife) I then marked the throttle position at idle with a little tension on the grip and then marked it at WFO. I also marked three in the middle at 1/4, 1/2 and 3/4. Got on the interstate and headed east to the interchange where I got on earlier.
I entered the west bound side once more and accelerated to 70 mph then shifted to 5th gear. I held the throttle grip to the maintenance level of 70 and noticed the mark lined up at a about 2mm over the 1/4 mark. Shifting to 4th and maintaining 70, the mark lined up at 1/4 nearly right on.
Now I know that this is not an earth shattering revelation but it seemed to clearly point out that it all comes down to speed vs horsepower or better put, the maintenance of each.
I may try this again using a single vacuum gauge to show the results more clearly.
Another analogy might be fun vs wallet.
