Using carbs as part of the intake manifolds
Rockdog
Post by Rockdog »
Came across a video on YouTube....guy used his carbs as part of the intake manifolds to keep it looking original....gutted them and put a single carb on top of the intake for air filter....tried to do a search....not much comes up.....any threads on this???
Re: Using carbs as part of the intake manifolds
It's been here before. Called a five barrel or six barrel.
UK_Andy
Post by UK_Andy »
Whats the youtube link please?
Ya, I'd like to see that as well
Rockdog
Post by Rockdog »
His videos are under...south west Florida aerial....on YouTube....put that in the search and should pop right up... only 3 or 4 vids all in the last month........one says triumph but half of that one is goldwing.....let me know what you think
Not knocking you, and we could do what you have described. But it is so much easier to just click on a provided link. ;)
robin1731 wrote:Not knocking you, and we could do what you have described. But it is so much easier to just click on a provided link. ;)
SOME can do what he said,.....But not all. I need a link to click on shakehands
Rockdog wrote:His videos are under...south west Florida aerial....on YouTube....put that in the search and should pop right up... only 3 or 4 vids all in the last month........one says triumph but half of that one is goldwing.....let me know what you think
I copied and pasted the red highlighted part. I don't think that is what you mean. This is what came up. https://www.youtube.com/results?search_ ... ida+aerial
mcgovern61
Post by mcgovern61 »
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
cmyoch
Post by cmyoch »
I like the concept. Would be cheaper to buy a mounting plate than an entire manifold. Plus, I love the idea of the stock look. I assume the butterflies were removed and that was about it?
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
An interesting way to do it,....if you want only one carb
cmyoch
Post by cmyoch »
CYBORG wrote:An interesting way to do it,....if you want only one carb
I spent an hour reading the SCC threads and it appears to have the same popularity as tire and oil threads. Mixed reviews, some discussions got a little heated also. To each his own. I think it was neat concept, just wish there was more to read up on.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
Visually it is a vast improvement over the normal installations.
I guess I grew up in and era where two carbs were better ten one, and four was even better. And I have seen no evidence that the single carb conversions create more HP, or help the performance of the engine, other then the seat of the pants feeling, which is often fueled by a lack of ability to tune multi carb. I hear very often "I'm going to convert to a single carb, because I can't get the stock ones to work".
cmyoch
Post by cmyoch »
Looks like the single setup is the path of least resistance for someone who just wants to hop on and go. I'm tickled knowing that I have enough knowledge to tune a complex 4 carb setup.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
The progressive two barrel still interests me. Tons of videos out there. When set up right, they sound like they rev quicker than cv carbs. Might be better acceleration, but might be trickier to manage in a curve. Still waiting for warmer weather and a report from Ron, hmbrtn and his four barrel.
