Ultrasonic cleaning
- mikenixon
- Early 'Wing Guru
Ultrasonic cleaning
Perhaps ultrasonic cleaning is a mystery to you. You've heard of it, but it remains "out there", unknown and considered only in terms of hyperbole and folklore.
Sometimes folks refer to ultrasonic units as vibrating machines. No. They do not work by vibration. If you understand boat propellers, you will understand ultrasonic cleaning. As a boat prop spins in the water, the shearing of the water actually slowly wears the prop's metal away, especially at its base. Boat techs call this "prop burn". It happens because the water the prop churns in cavitates. That is, oxygen in the water is abusively removed, cavitated out, from the water by the prop's movement, with the result a very forceful impact on the prop over its surface, steadily "sanding" away its metal. An ultrasonic machine works in much the same way. The ultrasonic machine's tiny cavitations, much smaller but more numerous than those happening around a spinning boat prop, and created by uber high frequency sound waves rather by than a rapidly rotating part, vigorously scrub the carburetor's surface in the ultrasonic cleaner's tank. The result is clean you have to see to believe. I have to change out my detergent every two weeks, before the dirt builds up like the slime on a creek bottom. So, cavitation, not vibration. And boy does that cavitation work!
Ultrasonic at various power levels is used to reclaim TVs from smoke damage. It's used as the final manufacturing step in computer parts assembly. Engine builders clean cylinder heads using it and gunsmiths firearms. Yet ultrasonic gently cleans jewelry too. Pretty amazing stuff.
There are a number of things you should know before buying an ultrasonic cleaner, and they almost all relate to how some manufacturers basically try to cheat you.
Wattage. When looking at wattage ratings attempt to separate the heater's wattage from the transducer's wattage. Manufacturers like to combine them for more impressive numbers in the brochure. Not only is this deceptive, a heater is an unnecessary expense, as anyone who has been around ultrasonic machines knows. And as for recommended wattage, pro work starts at the 250-watt point. Anything less is dabbling. To put it another way, $3000 is entry level for a carburetor cleaner. If that Harbor Freight unit cleans your carbs, then so would dunking them in gasoline. Seriously.
Capacity. Capacity is another slight-of-hand deal. A 10 gallon tank seems impressive, but not so much when you discover that the manufacturer achieved that volume by building the tank tall instead of wide. A too-tall tank moves the workpiece farther from the all-important transducers at the tank's bottom, making the sonic waves pass through more water, dissipating their effectiveness. It also leaves less room for the transducers, meanng too few are used, making the unreasonably deep tank less powerful for that reason as well. The best tanks are wider than they are tall. But these tanks aren't cheap.
Frequency. Wave frequency matters. The cheaper units run in the higher frequencies, typically 42-50 KHz, while the better systems run in the lower ranges, 25-40 KHz. A 45 KHz unit is for jewelry, a 25 KHz is for engine parts. Carburetors are best cleaned somewhere in the middle where the frequency is high enough that the waves get inside tiny carburetor passages, yet low enough to produce waves with the scrubbing power needed.
Chemicals. It is well known that ultrasonic machine makers try to make a killing on the cleaning chemicals they recommend and sell. Equally well understood is that in response, every ultrasonic user quickly discovers his own alternative, and that no carb rebuilder wants to divulge his secret formula. Forget Pinesol. If Pinesol will get your carbs clean to your satisfaction then so will paint thinner. Seriously. But neither is actually very effective, and more importantly, neither is safe in ultrasonic waves. Fire hazard? Better believe it. Think microwaves. Most carb rebuilders use some form of detergent in their ultrasonic units. You have probably heard of folks using Simple Green. But while it is a powerful detergent, you should know that pros don't regard Simple Green as an acceptable cleaner. Its high PH is reactive with aluminum, creating white fuzz on the carburetor bodies. Dilute? Well, you'd have to get it far too dilute to be effective.
Disassembly. Although there have been some folks promoting it, it is bad practice to try to take advantage of ultrasonic's cleaning power by not disassembling the carburetors. They must be completely disassembled. For one thing, left assembled, pockets of water will remain inside the carburetors, and this will react with the diecast aluminum main bodies, corroding them.
Incredibly, a few carb rebuilders have spoken out against ultrasonic cleaning. Without ultrasonic, you will necessarily be exposing yourself to chemicals that are carcinogens and known neurological hazards. Without ultrasonic you must find separate ways to clean plastic, rubber, steel and aluminum parts, not to mention tiny springs and diaphragms, all of which are safely and thoroughly cleaned by ultrasonic. Without ultrasonic, you are avoiding the very best way to free corroded-together parts. Without ultrasonic you have very limited options for removing minor oxidation. And without ultrasonic you miss the pleasure of seeing freshly cleaned carburetor castings glisten prettily almost as when they were newly made. Great stuff, ultrasonic! Coming up in the business as I did, I used the methylene chloride and other dunking chemicals long considered the only way to de-varnish a carburetor inside and out. Then I decided to give ultrasonic a try. I will never go back.
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
Re: Ultrasonic cleaning
Nice. Not something I ever plan to invest in as I would not have enough use to justify but great knowledge none the less.
- chewy999
Thanks Mike, always an interesting read.
- mikenixon
- Early 'Wing Guru
Mike Nixon
- HOTT
Spot on. Perfectly summed up.
I purchased my first ultrasonic cleaner in 2003. It had four separate compartments and baskets. It was a new exciting piece
of equipment then. We referred to it as the french fry tank. As you say it worked amazingly, but also increased our productivity quite a bit. Mechanics could continue working while more than one cleaning project was being done. I remember it being very expensive, but quickly paid for itself.
thanks
thanks
- mikenixon
- Early 'Wing Guru
Hott, you are welcome. Cool. It's still amazing to me how powerful the serious units are. Cylinder head guys use them. Now that is heavy duty!
Mike Nixon
Thanks for that write up Mike! I bought what I thought was a decent ultrasonic cleaner...have yet to use it. Probably won’t be as good as what you are using.
I picked up a bottle of Simple Green for the day I crack it out to rebuild the 78’s carbs.
After reading your post, I wonder if you would be willing to share what detergent you use in your cleaner?
- mcgovern61
I bought one of the inexpensive small units from Ebay. Small is the operative word here. I can only fit pieces of one 1100 carb at a time. BUT, it works great! I use 1 oz of Dawn dishwashing detergent to every pint of distilled water. I am very happy with the results.
- mikenixon
- Early 'Wing Guru
Excellent!
That's what matters.
Mike Nixon
- chewy999
I bought a small unit, 2 litres, off eBay. Not tried it yet and a bit disillusioned after reading Mike's piece. Now happy to give it a go, sure it will do for what I want.
- mikenixon
- Early 'Wing Guru
chewy999 wrote:I bought a small unit, 2 litres, off eBay. Not tried it yet and a bit disillusioned after reading Mike's piece. Now happy to give it a go, sure it will do for what I want.
Don't be. I expect a lot and get a lot from the equipment.
Mike Nixon
Based on the CBX rack I just received from The Motocycle Project, I’m a believer - especially given their sorry state when I sent them up. Thanks Mike!
I thought the ultrasound job I’d done on the original rack was good until I saw this one. Small commercial units simply do not compare.
- mikenixon
- Early 'Wing Guru
You are very welcome, Darrell! It's amazing how much oxidation is removed by ultrasonic. I keep liking it more and more. Let me know how those carbs work for you. And good luck in your new job!
Mike Nixon
