Leakdown tester: building your own
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post by mikenixon »
Inexpensive, ready-made leakdown testers are easy to find today -- you don't have to mortgage your house to a Snap-On dealer. Motion Pro has a fairly good unit.
You can also make your own. Here's the rundown:
Pressure regulator . This is an automotive paint spray gun part. Grainger's is probably the cheapest, followed by Sears and Ace Hardware. EBay too. The 0~160 gauge that often comes with these regulators is, unfortunately, the wrong kind for our purposes. So we'll need to replace it with a 0~100. See below. Also, make sure your regulator comes with the block-off plugs for the two passages that you won't be using.
Pressure gauge. Get a quality, back-mount, 0-100 psi gauge. For the professional touch, carefully pry off the bezel and cover the faceplate with a new label. If you don't feel like re-labeling the gauge, no big deal. But you'll then have to read the gauge backwards; i.e. "10" would mean 90% leakdown. Not an intuitive way to use the tool. Better to relabel.
Spark plug adapter. Start by by clamping an old NGK spark plug in a vise (protected with wood or aluminum stock) and whacking off the porcelain with a well-aimed lateral hammer blow. Then grind or machine off the rolled-over seal above the hex, grind off the ground electrode, put the plug back in the vise and drive out the remaining porcelain with a drift. Tap the hex end with a 1/4" pipe tap. Screw the bugger onto a 1/4" to 1/8" pipe reducer, and that onto a 12" grease gun hose. Use pipe-sealing tape on all threads. Make a separate complete hose assembly for each engine you're going to test that has a differently-sized spark plug hole.
Damper valve. This essential part damps the gauge's needle movement. It's merely a restriction between the regulator and the gauge. The easiest way to make it is to fill the middle pipe with epoxy and afterward drill through it a 0.040" (#60 or 1mm drillbit) hole. You could also machine a tight-fitting plug and drill it.
Parts List
Miniature air pressure regulator
0-100 psi gauge, back-mount, metal case, removable bezel
12" grease gun hose
1/4" NPT quick disconnect fittings
1/4" plumbing pipe and "T" joint
1/4" to 1/8" NPT reducers (2)
Old spark plug
Teflon plumber's tape
Re: Leakdown tester: building your own
Recommend folks scroll down this page to SIMILAR TOPICS, too to further understand the importance of this diagnostic tool. tumb2
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post by mikenixon »
Thanks, gltriker!
By the way, a notice to all:
I feel compelled to mention -- I originally wrote this article, including the drawing, when I first established a website back in 1997. It was virtually my first online article. I say this because several websites have copied it word-for-word, none with permission and only one with attribution. Even the drawing! If you see it or the drawing elsewhere, now you know. :)
Highly Recommended reading materials. :oldies
https://www.motorcycleproject.com/index.html#100
Nice, thanks man.
Return to “Mike Nixon's Spot”
