Custom Seat
JonathonCranny
My Album: https://myalbum.com/album/h3GKgpMuqLZQ
Custom Seat
Post by JonathonCranny »
So today I decided to get started on a custom seat. The reason for this project is the seats I've seen for the old Goldwing all rise at the back and are as wide at the tail as they are at the tank, none of them follow the frame of the bike.
I started out with a 3mm piece of Perspex and I'll put some fibreglass over the top to give it some strength and to tidy it all up.
The reason for the Perspex is that it's super easy the heat up and bend into shape as well as to cut and drill. I'll cut a piece of 9mm mdf timber and use some foam and vinyl to make the actual seat nice and flat like a tracker/scrambler seat.
I'll add some more photos as I go over the next couple weeks.
"Worrying about things is like sitting in a rocking chair, it will give you something to do but it will get you no where"
1975 GL1000 tumb2
1983lux
Re: Custom Seat
Post by 1983lux »
Nice, really interested to see how it turns out. Been wanting something like this myself but no real idea where to start.
1975 Honda GL1000 - Naked
Motor from 1981 1100
1975 Cams and Carbs
Dyna S Ignition
Re: Custom Seat
Nice starting techique.
JonathonCranny
Re: Custom Seat
Thanks guys...
I haven't spent much time on it over the past week but here's an update.
I needed to cut the Perspex to get it to shape to the frame and it was much easier to bend the edges in two halves, I didn't mention that in the first post.
I used some fibreglass filler to shape those parts and fill the gap between the cut.
I then started the fibreglass and it's my first time using it, man that stuff is sticky lol. I used a full sheet the first run and I folded over the edges and it was a bad idea to much to work with, I ended up with bubbles everywhere and in the end I sanded most of what I put on over the edges off. I would definitely recommend using smaller pieces, which is what I done on the second run.
1975 GL1000 tumb2
bigscheaf
Re: Custom Seat
Post by bigscheaf »
Looks like a good solution to getting the tracker look without having to modify the frame for the seat. And the ability to swap back to stork, of course.
Looks like a pretty good start! Be cool to see what it looks like in the end.
1983 GL1100 viewtopic.php?f=16&t=67673#
1981 CB900F (Resto-mod Project)
1979 CB750F (Wiseco 823)
JonathonCranny
Re: Custom Seat
Managed to make a little more progress over the past couple weeks.
1975 GL1000 tumb2
JonathonCranny
Re: Custom Seat
That's it Bigscheaf... one thing with this build is that anything I do to this wonderful bike can be changed back to the original Goldwing. :-D
1975 GL1000 tumb2
JonathonCranny
Re: Custom Seat
And the seat is done!!! Now for some work on other parts of the bike including some paint action1
1975 GL1000 tumb2
Re: Custom Seat
Nice work! (I like your protective gear, lol!)
Re: Custom Seat
Pretty much in 2 by 6 inch form. Stand over must be good.
JonathonCranny
Re: Custom Seat
Haha Track T 2411 good helmet that one.
1975 GL1000 tumb2
JonathonCranny
Re: Custom Seat
Huh Fred Camper? I couldn't make any sense of that...
1975 GL1000 tumb2
JonathonCranny
Re: Custom Seat
Added some Chrome turn signals and sorted the number plate and tail light.
1975 GL1000 tumb2
JonathonCranny
Re: Custom Seat
:-D
1975 GL1000 tumb2
Re: Custom Seat
Nice looks! Ride it like you stole it!
