How low is low?
Wangthang
How low is low?
Post by Wangthang »
From what i understand the gl doesn't have the greatest clearance for rolling thru curves. I've decided to make some rear struts. What would be a good length to maintain safety, and be as low as possible? I rarely scrape unless I'm in the mountains. Hold the "struts suck stuff", i got bikes with shocks.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
Re: How low is low?
I would be concerned about the angle of the drive shaft. And the biggest problem is the stock exhaust dragging. Raising the exhaust would be safer, and not create such a harsh ride
Re: How low is low?
Yeah, struts and cornering don't go together real well. Like Cyborg said move the exhaust up, maybe loose the center stand, and move the driver pegs up and back.
Wangthang
Re: How low is low?
Post by Wangthang »
Question of the day? So if an 11" shorty shock will work on a gl, shouldn't i he able to run a 10" strut? The shock comperssion of a shorty shock has to figure in somewhere. So other than harsh ride, cornering clearance is an issue. I already removed the center stand, raising the pegs pegs is doable, i can raise the muffler but the header is set. So 10 " struts?
1977 Gl 1000
1976 F1 750 SS
2007 Road King
600rr parts bike
Re: How low is low?
I had 11" shocks on my 75 for as while with the 4 into 1 header pipe. It was a real problem with ground clearance. In town it would hit on modest corners and going up the slight rise in the driveway. It was unusable in the twisties.
Re: How low is low?
Pegs are designed to scrape first and make you check you life insurance policies.
With the wider 1200 engine in a 77 frame and a slight rake in the front, I laid mine over in the garage and I thought the valve covers or case guards would hit first. Mine is lowered in the back by moving the 1100 rear shocks further rearward a few inches(3+”) I can raise the front forks four inches, but I prefer the bike to be level. It has shorter exhaust and no center stand. I’m not a twisty rider and have seldom scraped the pegs.
low-side
Re: How low is low?
Post by low-side »
To elaborate on Cyborg's point about the u-joint in the drive shaft, u-joints need to change angle and run at a certain angle in order to spread their lubricant around the bearing. I doubt it will last long nearly straight and in a fixed position.
Re: How low is low?
Forget the stiff ride. With struts the handling in corners will not be very good. Think about going around a curve and it having a series of bumps. Instead of a shock compressing to take the "shock" the whole bike takes it. The tire won't give enough to make any difference. You may very well end up sliding through that curve even taking it somewhat slow.
Re: How low is low?
I think it would be pretty easy to figure out (but I've never done it myself). Ride the bike and get a feel for what's a comfortable lean angle for you, then compare that with the static lean angle. You can easily make up some 'temporary' struts to check out various length-to-lean angle ratios and statically test them.
Re: How low is low?
Center stand is the first drag on mine. So nice you removed that first. I too think a stiff rear would break loose early in the curves as a divot in a corner will lift a tire on a strut that a shock would absorb and keep the tire in contact.
Re: How low is low?
Post by HOTT »
Wangthang wrote:Question of the day? So if an 11" shorty shock will work on a gl...
It seems you answered the title question. If you are shortening shocks and even shorter struts.. you are too low.
Now it is a question of how much you are willing to give up in safety and performance. I get low riding stance and look (I even get a hard tail), but it comes with a price. Sometimes it's fixed with a saw and a torch. :twisted:
Wangthang
Re: How low is low?
Post by Wangthang »
Ordered the 11" shorty shocks. Still gonna make a pair of 10" struts, for riding in the "ville". Lol
1977 Gl 1000
1976 F1 750 SS
2007 Road King
600rr parts bike
